Off Road Lighting - Ford Truck Enthusiasts Forums
Off Road Lighting
Old 05-08-2012, 04:33 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
Off Road Lighting
Im on the topic of off road lights. So i thought id come back to the mature area for some actual discussion (as the 4x4 section clearly is not the place...see recent thread if desired).
SO ...
topics of interest include:
Make / Model of lights and why
Legality of off road lights installed
and
Installation techniques
Old 05-08-2012, 05:20 PM
Andrew010's Avatar
Andrew010 Andrew010 is online now
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
No help on the lights, but WOW on your other thread. There's some quality people in that thread......
Old 05-08-2012, 05:24 PM
for the record, some of the other peoples comments have been deleted by the moderator. i couldnt believe it. sure, it was my first post in there... but i didnt think it warranted that type of treatment. i like the 6.7 crowd much better. clearly a more evolved bunch over here. ahh, glad to be back and sorry for the momentary venture to the dark side.
Old 05-08-2012, 06:32 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
I had 4 KC Slimlites on my 2000. They were awesome, insanely bright (imo), and you can't go wrong with KCs warranty. I had them mounted on a Randy Ellis Designs light bar. I had 2 fogs, 2 beams,they were blinding, and of course illegal out here in PA. I was living in AZ when I bought/installed them and used them at the dunes alot, never a problem with them.
They didn't last long here in PA though. Not a good environment for them. I ended up cutting some old flaps for covers so it would pass inspection.
Old 05-08-2012, 06:35 PM
good info. im lookin at the vision x 8510s pretty hard.... and they come with covers. the N FAB prerunner (lightbar) i ordered takes 3 lights. the visions are 100w each. which works out to around 8 amps each. i figure i can put all three one one of the 25 amp upfitters....
Old 05-08-2012, 06:54 PM
Cold One Cold One is offline
Cold One is gaining momentum as a positive member of FTE.
Dang, I was just checked your post and you somehow miffed off the whole trailor park with a question !! I to have the KC lights. I am not sure of the number but they are 120 watts and black powder coated to match our trucks. They are holding up great in the NY winters and not expensive.
Old 05-08-2012, 07:01 PM
120watts would put me over my power budget as im thinkin to put all 3 on one switch. but that brings up another thought i forgot to mention... what type of beam do you guys think? spot (pencil), euro, or cornering (dont even know what that is)...
Old 05-08-2012, 07:17 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Depends on the type of driving you do....
back roads and woods where the deer and the antelope play ? cornering
in the wide open spaces like here in TexUS - driving - spot...
cuz the rest of your lights will cover the sides, etc....
You got me thinking about the led lite bar too....
sure would look nice in place of my front license plate
Old 05-08-2012, 07:19 PM
Isnt the euro the mix of the various type? Aka best of both worlds
Old 05-08-2012, 07:25 PM
You could always use the smaller upfitter to power a relay and the lights. I am not sure what type mine are (i think spot light) I can look tommorow if you are interested. They light up nicely 200 yrds. long and 30 yrds. wide
dmags dmags is offline
dmags is gaining momentum as a positive member of FTE.
WOW.... THAT'S ALL I CAN SAY
Old 05-08-2012, 07:26 PM
Isnt the euro the mix of the various type? Aka best of both worlds. Maybe one spot in the center facing straight ahead and then two euros or cornering on the outside facing slightly outward
Old 05-08-2012, 07:29 PM
Quote:
Pretty sure the upfitters are already have relays on em rated at the corresponding power
Old 05-08-2012, 07:33 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
You can only do three lights with that bar? I did 4 lights on my last truck, 2 beams on the outside pointed towards ditch (lots of deers and moose up here) with floods down the middle. Worked pretty good, 130w each, ran them off a seperate relay.
Old 05-08-2012, 07:35 PM
farmerdave farmerdave is offline
farmerdave is gaining momentum as a positive member of FTE.farmerdave is gaining momentum as a positive member of FTE.
I agree with Cold One's idea about the relay.
Slightly off topic, but is anyone working on "flipping" the headlights with the marker lights? I'm thinking there would need to be an all new reflector assembly swaped for the factory. I need a higher light beam to shine over my crops.
2008 E250 LIGHTING ROADHOGE250 1968-2013 Full Size Vans 17 12-12-2016 06:06 PM
Bilstein? Monroe? Rancho?... other? Farflunged Explorer, Sport Trac, Mountaineer & Aviator 7 05-15-2016 08:56 PM
2002 F250 4x4 ESOF Problem Ahles3 1999 to 2016 Super Duty 13 01-21-2016 01:59 PM
Electrical Gremlins blank Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 01-05-2015 09:09 AM
1990 E350 - Electrical Gremlins blank 1968-2013 Full Size Vans 2 01-02-2015 03:21 PM
Tags
18, 260, 40, article, bike, carbon, center, dashboard, film, lights, motorcycle, northern, powered, privacy, regional, road, tires, vbulletin, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
