Off Road Lighting - Page 2 - Ford Truck Enthusiasts Forums
Off Road Lighting
Old 05-08-2012, 08:36 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
Up to three 9" lights. 4 is a bit much for me.
Old 05-08-2012, 08:43 PM
heres the light bar.
Manufacturers of high quality Nerf Steps, Prerunners, Harley Bars, Light Bars, Replacement Front Bumpers, Rock Rails, Rear Runners, Tire Carriers & Truck Accessories
so your saying go with a dual relay setup? fords relay and then the relay that comes with the light?
Old 05-08-2012, 09:01 PM
just to be clear... the upfitter switches control relays. those relays are what accessories are connected to. the switches themselves can only handle enough current to power the relays. but it seems as if some of you are suggesting using different or additional relays from what i gather. not sure why tho
Old 05-08-2012, 09:03 PM
Cold One Cold One is offline
Cold One is gaining momentum as a positive member of FTE.
You could or you can use a bigger (correct amperage) relay and the switch and unhook the factory relay if desired to simplify and eliminate a fail point. When I redo mine this fall I will have four on a randy ellis bar on the bumper and two on my ladder rack. All lights will be on the same switch (it suits my purpose).You can modify the switches and relays to suit your purpose if you need additional amperage for lighting etc. as long as the wire and fuse sizing is correct
Old 05-08-2012, 09:07 PM
ive got two 25 amp switches and a 15amp remaining. and since the lights im lookin at are rated at 100w and 7.14 amps (100w/14v=7.14a) and 7.14x3=21.42amps i think i should be fine with the stock relays
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
I'm not sure about doing dual relays, I just used a seperate relay and switch. I don't think you are stuck with the relays in your upfitters, I think they can be changed out for a bigger one, not 100% sure through. more questions, not much help...
Old 05-08-2012, 09:09 PM
ever hear the saying "better is the enemy of good enough"?
Old 05-09-2012, 08:49 AM
Great Danes's Avatar
Great Danes Great Danes is offline
Great Danes is starting off with a positive reputation.
I would highly recommend going with Rigid Industries and one (or combination) of their LED light bars. I have two Dually D2s on my motorcycle and these are really nice bright lights that are virtually indestructible. My bike is dual sport that heads off road on a regular basis and these lights have performed flawlessly.
Admittedly, they are a little more expensive, but since they are LED, the power draw is minimal and it wouldn't be too difficult to wire them into the high beam circuit with a relay, or wire them to your upfitter switches. Rigid even has a specific light bar and mount to fit in the front bumper of our trucks between the tow hooks. Good Luck.
Old 05-09-2012, 08:52 AM
Ya but theyre stupid expensive ...
Old 05-09-2012, 10:19 AM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
If we didn't have the front plate law in Wisconsin, the 20" Rigid would be on my truck for sure. My cousin has dual 6" on the front of his Tundra and they work really well.
Old 05-09-2012, 12:53 PM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
Old 05-09-2012, 02:39 PM
sanjuanfly sanjuanfly is offline
sanjuanfly is starting off with a positive reputation.
Quote:
+1
They want $760 for just the bracket then another $700 for the 20" lightbar.
  #28
Old 05-09-2012, 02:44 PM
Quote:
Originally Posted by sanjuanfly View Post
+1
They can stick it in their light socket. The n fab prerunner is 300 shipped and waaay cooler. And then you can choose whatever light set up u want.
  #29
SavageNFS's Avatar
not a WHITE truck
+1
This is not true...the light is included per the product description. Not saying it's inexpensive, but it isn't $1460 for the lightbar for the SDs.
Quote:
In stock and ready to ship is the all new LED light bar kit for the 2011 & 2012 Ford F250/350. This kit comes with all the hardware needed for a no drill install. The light is also included. Utilizing existing bolt holes this kit will mount a 20" E-series light bar in the lower grill opening. Includes full color instructions.
Rigid product description
  #30
Old 05-09-2012, 02:57 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
PITS !!!
that is Coo- WELL !!!! another option
Which is that ?
the M&R LED lightbar you have in your signature ?
Home - M & R Automotive
led light bar by "M&R" 24" 120W 40LED * 2 - YouTube
Bilstein? Monroe? Rancho?... other? Farflunged Explorer, Sport Trac, Mountaineer & Aviator 7 05-15-2016 09:56 PM
This topic seems to come up frequently so here's a link...2wd to 4wd conversion jtrux 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-28-2014 01:10 PM
Aftermarket off-road light installation I8AHEMI 1999 - 2003 7.3L Power Stroke Diesel 6 01-09-2012 12:31 AM
Flashing OD light on '95 Explorer soundman502 Explorer, Sport Trac, Mountaineer & Aviator 16 07-28-2011 10:40 PM
Off Road Lights (Post Pics!) A/Ox4 1999 to 2016 Super Duty 19 05-08-2011 12:33 AM
Tags
18, 260, 40, article, bike, carbon, center, dashboard, film, lights, motorcycle, northern, powered, privacy, regional, road, tires, vbulletin, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
