Dashboard Lights out - 1979 Ford F-350 Custom
Hey Guys - I have a 1979 Ford F-350 Custom that I bought about a year ago. Great looking Truck.
However, my dashboard lights don't turn on. I am fairly new with these trucks, but do you know if when I turn my headlights on, my dashboard lights should automatically turn on? If so, they dont. I'm thinking that it may be a fuse or something. Any advice on how to get to the wire switchboard for the Dashboard lights? Any thoughts are much apprecaited.
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
I Checked all the fuses and found out that i was not getting current to that fuse.
I recommend you checking them
The light switch can be turned to the left and right and by doing that it acts as a "dimmer" switch for the dash lights. Sometimes the effect can be minimal depending on the age. If there's no lights at all, then it's either a fuse or bulb issue. To get to the bulbs, you will probably have to remove the instrument cluster.
Truck Guy99
04-19-2015 11:26 AM
J-W
03-06-2011 04:52 PM
kckracker
10-16-2010 10:27 AM
nickbaize
07-17-2010 03:27 PM
