PCM problem, please help ASAP!
Old 05-08-2012, 10:26 AM
Dieseldoe96's Avatar
Dieseldoe96
Dieseldoe96 is offline
My PCM is burned up. I have pulled it out and taken it to the auto part store, but I don't know the calibration number. I have looked on the VIN plate on my dash, not there. I have checked the tag on my door, not there even the stickers are not there. I checked under my hood, not there not even any identification stickers anywhere. I have looked all over the PCM itself, not on there. Can I get the calibration code some other way? Is it possible to type my VIN number in somewhere and it tells me what my calibration number is? Can I order a PCM without the calibration code? Need help please, thank you!
Old 05-08-2012, 10:35 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
I assume by the calibration code you are talking about the flash version on the PCM? If that's the case why not just order the latest one for the configuration of your truck?
If that is indeed what you need, HERE is a link for you:
Old 05-08-2012, 10:52 AM
Dieseldoe96
Thank you for the reply. That looks pretty helpful, so now I just need to figure out which
one to use. How do I know which is the correct one on that list? I have a 96 f350 automatic.
Old 05-08-2012, 11:34 AM
blageurt's Avatar
blageurt
blageurt is offline
TEE4 , TEE5 ,TDEO,TDE1, PRE5 , PRE6 , will all work fine.....Assuming you do not have a Cali truck ....
Old 05-08-2012, 11:38 AM
Talyn's Avatar
Talyn
Talyn is offline
Actually, the best way to really handle this is to just send it to Jody at DP tuner.
Old 05-08-2012, 03:35 PM
Dieseldoe96
Talyn
How much does Jody charge at DP Tuner? I would love to get performance upgrades instead of putting stock parts in.
Blageurt
Thanks for the info!
Thank you everyone, can't wait to get my truck back on the road.
Old 05-08-2012, 04:21 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Jody can flash one tune on the stock pcm. And, its only 100 bucks, give or take a little. I agree with Talyn (william), that is what I'd do.
Old 05-08-2012, 06:01 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Send DP-Tuner an e-mail. James will get back to you ASAP.
Old 05-08-2012, 10:59 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
But he said it was burned up, does Jody fix PCM's?
Old 05-08-2012, 11:32 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Well I'm not sure what the OP really means by
burned up
but it couldn't hurt to contact DP one way or the other.
Old 05-09-2012, 12:02 AM
BuckHammer's Avatar
BuckHammer
BuckHammer is online now
It's a pretty expensive procedure to pack all of that electrical smoke back up inside the PCM and then seal it up in there good. I'm pretty sure that's how that works.
(consider this post a free bump)
Old 05-09-2012, 12:07 AM
oldbird1965
Your a funny guy Joseph!
Old 05-09-2012, 07:43 AM
Talyn's Avatar
Talyn
Talyn is offline
That is correct sir.
Old 05-09-2012, 07:44 AM
Talyn's Avatar
Talyn
Talyn is offline
Originally Posted by pjwoolw
Well I'm not sure what the OP really means by but it couldn't hurt to contact DP one way or the other.
We just had a guy say his motor was blown up, but it still runs.
So.....
Old 05-09-2012, 10:14 AM
Dieseldoe96
Well I don't know what the dude that told me it is burned up meant, cause it is still grey in color and I didn't smell smoke! Can local repair shop flash a PCM? How long does it take? Thanks for all the info everyone
Quick Reply: PCM problem, please help ASAP!
