Looking at a 2007 F150 4x4 XLT - Ford Truck Enthusiasts Forums
Old 05-08-2012, 08:36 AM
CPT_Diesel's Avatar
CPT_Diesel CPT_Diesel is offline
CPT_Diesel is starting off with a positive reputation.
Hello all,
I am looking at a 2007 XLT 4x4. Build date is 5/07, so from what I read it may have the spark plug issue but probably not the cam phaser issue.
64K miles, quiet, no knocking or ticking.
It was just run thru a local Ford dealer for their multi point inspeciton.
I am thinking of doing a prepurchase inspection to check for signs of the cam phasers and to check oil psi since I read about some issues with the oil pickup in the pan.
Will the Ford dealer be able to do that? Is it easily detectable, or will I get the same info by warming it up and listening?
Thanks!
Old 05-08-2012, 11:25 PM
dilas dilas is offline
dilas is gaining momentum as a positive member of FTE.
If you want to do pre purchase inspection, you would be better off doing it (independent shop) outside of the dealer lot. No biased result.
Those 04-08 trucks aren't quite perfect but they're darn good. Love them to death.
I have 07, it's excellent, and yes I'm concerned about spark plugs breaking. But would replace them early around 60K instead of 100K.
Old 05-09-2012, 01:23 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
go in early morning, start the truck yourself from a cold start
listen to the valve train. a little clicking is normal (injectors). Anything louder though means issues. I've heard a few trucks that are as loud as your/mine PSD
as for spark plugs...way overblown. The removal tool is $100. If they break, buy or rent the tool and get them out. It's not overly hard. Several guys even have DIY removal tools that cost <$5 to assemble.
As for oil, just check the color and look at the bottom of the fill cap. These motors commonly form a whitish foam around the cap. It is condensation formed after many short trips where the motor didn't get to operating temperature.
Oil color should be light Karo (corn syrup) to a darker amber. Avoid anything brown or black.
The 06+ trucks were damn fine machines...so were the 04-05's after a few stumbles. I suggest you take it out on the highway and see how the Cruise Control works. Then floor it a couple of times and see how the transmission reacts.
oh yeah, the trans has an adaptive feature. It learns how you drive. So if you do buy the truck, I highly suggest you unplug the batteries for >30 minutes to clear the PCM. It'll run funky for a few miles, but then she'll smooth out and start learning your driving quirks
Old 05-09-2012, 06:12 AM
CPT_Diesel's Avatar
Thanks, its a private sale and I am meeting the guy at the local Ford dealer for a pre-purchase inspection.
I need to update my sig. Sold the PSD a few years ago and miss having a truck!
Old 05-09-2012, 09:37 AM
Tylus's Avatar
Submarines Once....
I would meet him at his house instead and hear it from a cold start. Just me though.
How much is the Dealership charging to inspect?
Old 05-09-2012, 02:42 PM
CPT_Diesel's Avatar
It was $115 and I asked them to run an OASIS and they did. It showed no warranty work at all.
Old 05-09-2012, 04:09 PM
Tylus's Avatar
Submarines Once....
Not overly bad
You buy it?
Pictures?
Old 05-10-2012, 03:08 PM
CPT_Diesel's Avatar
Yeah, working the loan process now. Will post pics when thing are finalized.
I am considering a vehicle warranty thru my bank just in case of the cam phaser issue. I wonder if that is considered normal wear and tear?
Old 05-10-2012, 04:10 PM
Tylus's Avatar
Submarines Once....
Normal wear/tear is brakes, clutch, wiper blades...etc
Cam Phaser is a motor failure IMO
Btw, after you get it, change the oil with Motorcraft FL-820s filter, and I highly highly suggest only using 5w20 per Owners Manual
The 5.4 3v is particular about her oil. 5w20 is good enough for 500+ RWHP motors, and served me great with my Supercharged 5.4 3v
Old 05-10-2012, 07:46 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
Before you take possession make sure the 4wd shift motor works as well. And Rock Auto sells the Lisle spark plug removal tool for about $65 plus shipping. Rock Auto is also the cheapest place I've found for tune up parts too.
Old 05-11-2012, 12:17 PM
CPT_Diesel's Avatar
This truck has a manual 4x4 shifter! I found that odd, since just about all the F-150s I've seen have the electronic shift on the fly. It's nicely optioned otherwise, so I wonder if it was special ordered with the 4x4 on the floor.
Has 3.55 LS axle, premium sound, auto headlights and steering wheel controls.
Old 05-11-2012, 10:37 PM
Manual shift transfer case was standard on most trucks with 40/20/40 seating in front. ESOF is mandatory with captains chair seating arrangement like I have on mine. Sounds like it'll be a fine truck. I bought an SCT x3 programmer with custom tunes for my truck and the driveability is really improved. There is no more hesitation when I mash the throttle and it shifts so much better. I can't say fuel mileage increased any, but driveability sure made the purchase worth the expense. I also have 3.55 L/S and even with those gears it pulls my enclosed 20' car trailer just fine. I get slightly better mileage than I did with my 05 PSD empty and within 1 mpg towing of the diesel. The only other area you may have problems with are the power window switches. I've had to replace them once in both front doors.
Old 05-12-2012, 05:04 PM
CPT_Diesel's Avatar
Cool, thanks for the info. It does have the 40/20/40 seats.
I picked up the Motorcraft filter and 5w20 today. Hope to get the truck soon, waiting on the sellers lien to clear.
Reliability of 3 valve 5.4 JDMitchell 2004 - 2008 F150 8 02-07-2016 07:13 PM
Trade in or fix 2005 F-150 with 5.4 3v? 1964f-100 2004 - 2008 F150 12 06-20-2015 04:27 PM
2007 5.4 Cam Phasers jerem0621 Modular V8 (4.6L, 5.4L) 1 06-18-2015 10:08 AM
Cam Phasers, Timing Chain, Bad Fuel Economy ??????????? jessecam 2004 - 2008 F150 0 07-22-2014 07:18 PM
2005 F250 5.4 Cam Phasers HELP !!!! thomas_e102 1999 to 2016 Super Duty 13 09-05-2010 11:05 AM
Tags
07, 150, 20042008, 2007, 4x4, black, decals, f150, ford, plug, plugs, removal, rental, spark, tool, troubleshooting, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
