02 e-150 fuse box diagramme,no high beams - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-08-2012, 09:09 AM
prop prop is offline
prop is starting off with a positive reputation.
when i put on the brights just goes black.thought maybe it`s a fuse but can`t find any kind of diagramme.thansk for any help
Old 05-08-2012, 04:48 PM
PStruwing's Avatar
PStruwing PStruwing is offline
PStruwing is gaining momentum as a positive member of FTE.
Prop Dude! Give us a bit more info to work with.
Old 05-09-2012, 07:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
That is helpful is it not PST?
Prop here's what I think you're seeking:
These images might not be clear enough to show Fuse #30, 15 amp controls the high beam function.
HTH
Old 05-09-2012, 08:09 AM
thanks thats what i was looking for.sorry but i didn`t think there would be any big difference in the e 150 series.it` a six ,air ,no electric windows or any of that 2002 with 85,000.
Old 05-09-2012, 08:19 AM
JWA's Avatar
JWA JWA is offline
You'll tend to find many of the E vans have somewhat of a common wiring scheme, within a few model years anyway. I alternate between an EVTM from 1997 and 2000 myself---they're quite similar.
In another thread I posted this link to an EVTM cheap on eBay---might want to consider one for yourself too: 2000 Ford ECONOLINE VAN Wiring Electrical Diagram Service Shop Repair Manual EWD | eBay
One handy thing to have around!
Old 09-26-2015, 03:49 PM
Chad Buhrandt Chad Buhrandt is offline
Chad Buhrandt is starting off with a positive reputation.
Thank you, I just fixed a half burned out dome light fuse with this diagram.
Old 09-26-2015, 05:22 PM
tx2sturgis's Avatar
tx2sturgis tx2sturgis is offline
tx2sturgis has a very good reputation on FTE.tx2sturgis has a very good reputation on FTE.tx2sturgis has a very good reputation on FTE.
Question inquiring minds want to know
Quote:
Resurrecting old threads huh?
What did you mean by 'half burned out'?
Old 11-25-2015, 11:58 AM
Dr. Johnson's Avatar
Dr. Johnson Dr. Johnson is offline
Dr. Johnson is gaining momentum as a positive member of FTE.
Just out of curiosity what dome light was out in your van? I too have some mysterious dome light issues in my '01.
Fuse panel BamainCT 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-26-2016 04:25 PM
No Power to Vacuum Pump!!! jayc3169 6.0L Power Stroke Diesel 7 05-06-2015 04:04 PM
Again...Vacuum leak in a 5.4 DOHC 32V Intech laxxx Expedition & Navigator 12 01-02-2014 11:21 AM
Interior pic help (jumpseat to console swap) kartracer22 1999 to 2016 Super Duty 3 06-22-2013 05:35 PM
02 e-150 v6 fuel pump fuse? prop 3.8 & 4.2L V6 0 04-30-2012 08:37 AM
Tags
1996, 99, beam, beams, box, brake, diagram, duratec, e150, engine, f150, ford, fuse, high, not, vulcan, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
