Ford reman HD4R100?
What dealership did you go to? If its not too far from me maybe I will check them out, my dealership is soooo against chips.
That is exactly what my trans feels like. To the OP, your leak sounds like a different story, you are probably right to be looking into this now before its too late.
I want those smooth shifts!!
As for your shifts, it's just a tune thing. Make careful note of where all your hard shifts occur - throttle position (Light, Medium, Heavy acceleration) and which shifts: 1-2, 2-TQLU at about 35 MPH, and TQLU to OD at about 45 MPH. Tell DP tuner where and when each crunch occurs and they can get it a lot closer the next time around. Since I have the convenience of the F6 chip (like you), we just kept at it until he nailed it. Live tune by proxy... gotta love it.
If it is just the front seal, you can drop the transmission and replace the front seal. That is actually a pretty common issue on the E4OD and the 4R100's.
I have the HD4R100 and have had no issues with it. You may call up Tousley Ford and see what kind of deal they can swing. Even with shipping it may be cheaper.
I was turned onto the HD4R100 by John Wood when mine died and I needed a replacement quickly. JW told me it was a good candidate and was similar to his Towmaster. With his recommendation I went to the dealer and bought it (they didn't have any knowledge of it at the time and was the first time they had heard about it).
This should give you the P/N information you need.
Part Number Reference
Service Part Number Motorcraft HD4R100 TRM Number
1999 4R100HD Super Duty 4X2 F250, 350, 450, 550 7.3L F81Z7V000HBRM 6U2Z7V000HRM TRM-1621
1999 4R100HD Super Duty 4X4 F250, 350, 450, 550 7.3L F81Z7V000LBRM 6U2Z7V000LRM TRM-1622
2000 4R100HD Super Duty 4X2 F250, 350, 450, 550 7.3L F81Z7V000HBRM 6U2Z7V000HRM TRM-1621
2000 4R100HD Super Duty 4X4 F250, 350, 450, 550 7.3L F81Z7V000LBRM 6U2Z7V000LRM TRM-1622
2001 4R100HD Super Duty 4X2 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000EBRM 1C3Z7V000ERM 6U2Z7V000ERM TRM-1619
2001 4R100HD Super Duty 4X4 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000FBRM 1C3Z7V000FRM 6U2Z7V000FRM TRM-1620
2002 4R100HD Super Duty 4X2 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000EBRM 6U2Z7V000ERM TRM-1619
2002 4R100HD Super Duty 4X4 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000FBRM 6U2Z7V000FRM TRM-1620
2003 4R100HD Super Duty 4X2 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000EBRM 6U2Z7V000ERM TRM-1619
2003 4R100HD Super Duty 4X4 F250, 350, 450, 550 EXCURSION 7.3L 1C3Z7000FBRM 6U2Z7V000FRM TRM-1620
Trans Faailure
Your fluid leak is from the trans front seal that gets weak when it gets hot. Then it pukes fluid.
I had a buddy working for me and his did the same thing. We drained it, filled it with synthetic fluid and it has held up for the past 5 years.
The front seal leaking does not mean your trans is going, just that the seal is weak. Of course, running a trans with low fluid will kill it.
#28
Part Name TRANSMISSION ASY
MSRP $3,469.33
Core $1,000.00
Online Price $2,862.20
That should be the HD4R100 for a 4x2
#29
Thanks , now I can go educate the dealership. For those that have it. Is it a big difference over stock on the take off? I know if I tune it it will void the warranty( I know i know the big 2 don't) so I am wondering if I need to leave it off for a while. But it's just so slow on the take off. Lol
