Loss of electrical power - Ford Truck Enthusiasts Forums
Old 05-08-2012, 08:27 AM
fixdent fixdent is offline
fixdent is gaining momentum as a positive member of FTE.
Yesterday my son was on a 300 mile trip pulling a car trailer. While driving in the rain, all electrical shut off, wipers, dash lights, everything. The truck coasted to a stop on the side of the road.
He tried the key...nothing.
He jumped out opened the hood and checked the battery connections. They were tight. Looked around, couldn't see anything. He slammed the hood (gonna call home) and everything started up. (Not the engine, he had to turn the key) He must have left the key on, wipers started, dash lights came on. He drove home without incident. I drove around last night and couldn't get the problem.
Anyone else have any problem of this sort,....??
Gordon
Old 05-08-2012, 05:00 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Not sure, Gordon. Intermittent problems suck, with any luck it will either never happen again or often enough for your dealer to track it down.
Old 05-08-2012, 05:56 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
The only thing I could suggest is do a wiggle test on wire looms. Gentle start to move looms just a little at a time. I have found tons of problems with that method. I wish you the best. Paul
Old 05-08-2012, 06:38 PM
Cable Guy Cable Guy is offline
Cable Guy is starting off with a positive reputation.
I had a volkswagon do that to me several times. I would be driving along and everthing would shut off. It was a five speed and I could pop the clutch and it would just take right back off again. Dealer tried the trial and error appoach and could not find the problem. They finally went through the entire electrical system and resoldered all the electrical connections and I never had the problem again.
Old 05-08-2012, 11:33 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Isn't there an issue on a few trucks where the front suspension rubs the wire bundle on the left side?
To add to Hdslider's idea, inspect and/or gently poke on that bundle (also) to see what happens.
Old 05-09-2012, 08:30 AM
Hdslider's Avatar
Kper 05. Indead on the left inner fender right above spring. There is a wire harness that is known to have rubbed through. It lays right on steel.
Old 05-10-2012, 08:29 PM
I'll have a look for that.
I've been driving the truck all week, and no issue. I'm pulling my 5th wheel for an 1200 trip in three weeks, so I hope all is ok.
gordon<!-- / message -->
Parking lights won't turn off Belt Driven 1999 - 2003 7.3L Power Stroke Diesel 22 06-11-2016 06:15 PM
'86 F150 5.0 EFI completely dead electrical RyPow 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-08-2011 11:16 AM
Ford Focus starting problem hancockr General Automotive Discussion 0 12-13-2010 03:09 PM
Rain causing elec. short. mikemonce Electrical Systems/Wiring 2 02-18-2008 09:49 AM
Transmission Malfunction FordOwner49 1997 - 2003 F150 5 08-18-2006 08:02 AM
Tags
250, 73l, 78, article, carolina, dashboard, electric, electrical, f250, ford, lose, losing, loss, make, power, powered, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
