Pulling a camper
#61
If your truck has power brakes, I have heard of a few exceptions, although I can't answer why Ford did it that way.
#62
For the original poster... if you change from the original 2.47 to a 3.55 differential, that is a 43.72% change which is huge [ask me how I know]. Your speedometer will indicate 79 mph @ a true 55 mph.
My son's truck with like change is definitely much more fun to drive and lost about 2-4 mpg on the interstate.
#63
I think my ideal ratio with the SROD transmission, which all three examples had, would be what was offered in the 9" differential... 3.25.
#64
That is a cover, like a dana44 or 10 bolt, just different shape. They bolt onto the rear of the diff just like the others do. Think the Ford 9" is the only one with a removable pumpkin. Most all other diffs have a axle mounted pinion/gear/axles and a removable cover to service/change fluid. Unless I'm not understanding what your saying, which is REAL possible.
But either way, he's got some work to do if he wants to safely pull anything. I helped my friend swap rear ends on mine before I bought it from him. It had the same setup I think this guy has and it would hardly get out of it's own way empty. SROD 4sp and 2.47 gear even with the factory 215/75 tires is geared way high.
Yep....you are absolutely right!!! I had 9" in my head the whole time while we were discussing an 8.8. I was thinking of my F100 that has the 9". For some reason I thought the earlier 8.8" were like the 9" with the removable carrier.
Phillip03
10-09-2015 12:49 AM
jdgoodnite
06-14-2012 04:28 AM
jim henderson
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
10-14-2002 03:13 AM
