Anyone running duralast clutch kit on a work truck?
I have a new clutch kit and flywheel in my 150 4.9 m5od 4x4 3.55 gears been in it for 3 months but today my buddy got stuck I was in high 1rst gear on greasy mud the clutch started burning and smokin. Tires wouldnt spin anyone else use autozone kits?
Duralast has to be the worst brand of clutch i have ever driven. You can forget spinning tires, instead you will do clutch burnouts. Also with the duralast kit the clutch was very hard to push down.
"Installed" kind of implies you paid to have the work done.
Rangergirl, why on earth would you go to Autozone and get whatever made in China crap they sell for a clutch kit? I figured you have been around these forums long enough to know better!
My buddy uses a center force in his pulling truck. It definitely grabs like nothing else I've ever used.
When I replaced the clutch in my truck I got whatever severe duty kit that Carquest sells. I will say that I'm not overly impressed with it, but it doesn't slip or anything with a load behind the truck or when I pull out stuck vehicles so that's a plus.
