Anyone running duralast clutch kit on a work truck? - Ford Truck Enthusiasts Forums
Old 05-07-2012, 07:51 PM
rangergirl94's Avatar
rangergirl94 rangergirl94 is offline
rangergirl94 is starting off with a positive reputation.
I have a new clutch kit and flywheel in my 150 4.9 m5od 4x4 3.55 gears been in it for 3 months but today my buddy got stuck I was in high 1rst gear on greasy mud the clutch started burning and smokin. Tires wouldnt spin anyone else use autozone kits?
Old 05-07-2012, 07:57 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Never have had any luck with the junk that they sell.
Old 05-07-2012, 10:39 PM
76250_4x4's Avatar
76250_4x4 76250_4x4 is offline
76250_4x4 is starting off with a positive reputation.
Duralast has to be the worst brand of clutch i have ever driven. You can forget spinning tires, instead you will do clutch burnouts. Also with the duralast kit the clutch was very hard to push down.
Old 05-08-2012, 12:26 AM
What is a good clutch kit to get I work my truck so I need durabilty
Old 05-08-2012, 10:01 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
I used a Sachs Slave Cylinder, and Clutch Kit...
I can't remember the name of the Flywheel I used..
All in all, $274 Installed...
Old 05-08-2012, 11:18 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You paid $274 for a clutch AND it was installed for that price?
To the OP, look in to a LUK clutch or Borg Warner
Old 05-08-2012, 11:41 AM
I did the work myself...
Clutch, Pressure Plate, Throw Out Bearing, Flywheel, and Slave Cylinder...
Old 05-08-2012, 12:50 PM
Then I wouldn't call that "Installed"
Old 05-08-2012, 01:05 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
"Installed" kind of implies you paid to have the work done.
Rangergirl, why on earth would you go to Autozone and get whatever made in China crap they sell for a clutch kit? I figured you have been around these forums long enough to know better!
Get a Luk kit.
Old 05-08-2012, 04:13 PM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
Luk, Hays, or even FoMoCo. Always spend the money and buy quality parts the first time.
Good Luck.
Old 05-08-2012, 08:48 PM
Yea I screwed up I was on a tight budget
Old 05-08-2012, 09:46 PM
Installed is self explanitory.....Whether paid, or by myself...
If I'd have paid for it...I'd have listed it as a PAID installation...
Old 05-08-2012, 10:01 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
i hear center force has some serious stuff
Old 05-08-2012, 10:34 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
My buddy uses a center force in his pulling truck. It definitely grabs like nothing else I've ever used.
When I replaced the clutch in my truck I got whatever severe duty kit that Carquest sells. I will say that I'm not overly impressed with it, but it doesn't slip or anything with a load behind the truck or when I pull out stuck vehicles so that's a plus.
Old 05-08-2012, 11:37 PM
Quote:
Centerforce is HD towing/Racing...So yea...They're serious...And serious $$$ too...
IIRC...A M5OD clutch kit from them was a mere $450...
What clutch kit??? GAHIGHRIDER 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-20-2016 08:50 AM
1966 Ranchero - Clutch lauxg Ranchero & 1961 - 1967 Econoline 9 09-02-2015 09:20 PM
Is this a dragging clutch? Whats causing it? 1990fordf-250 1987 - 1996 F150 & Larger F-Series Trucks 5 12-21-2014 05:41 PM
South Bend Clutch JHoffman93 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 34 01-14-2010 10:00 AM
C-6 transmission mybetom Clutch, Transmission, Differential, Axle & Transfer Case 2 09-07-2003 02:59 AM
Tags
1997, 73, big, block, clutch, dura, duralast, durlast, f250, f350, flywheel, good, kit, review, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
