Anyone running duralast clutch kit on a work truck?
Old 05-07-2012, 07:51 PM
rangergirl94's Avatar
rangergirl94
rangergirl94 is offline
I have a new clutch kit and flywheel in my 150 4.9 m5od 4x4 3.55 gears been in it for 3 months but today my buddy got stuck I was in high 1rst gear on greasy mud the clutch started burning and smokin. Tires wouldnt spin anyone else use autozone kits?
Old 05-07-2012, 07:57 PM
critterf1's Avatar
critterf1
critterf1 is offline
Never have had any luck with the junk that they sell.
Old 05-07-2012, 10:39 PM
76250_4x4's Avatar
76250_4x4
76250_4x4 is offline
Duralast has to be the worst brand of clutch i have ever driven. You can forget spinning tires, instead you will do clutch burnouts. Also with the duralast kit the clutch was very hard to push down.
Old 05-08-2012, 12:26 AM
rangergirl94
What is a good clutch kit to get I work my truck so I need durabilty
Old 05-08-2012, 10:01 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
I used a Sachs Slave Cylinder, and Clutch Kit...
I can't remember the name of the Flywheel I used..
All in all, $274 Installed...
Old 05-08-2012, 11:18 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You paid $274 for a clutch AND it was installed for that price?
To the OP, look in to a LUK clutch or Borg Warner
Old 05-08-2012, 11:41 AM
SideWinder4.9l
I did the work myself...
Clutch, Pressure Plate, Throw Out Bearing, Flywheel, and Slave Cylinder...
Old 05-08-2012, 12:50 PM
Diesel_Brad
Then I wouldn't call that "Installed"
Old 05-08-2012, 01:05 PM
andym's Avatar
andym
andym is offline
"Installed" kind of implies you paid to have the work done.
Rangergirl, why on earth would you go to Autozone and get whatever made in China crap they sell for a clutch kit? I figured you have been around these forums long enough to know better!
Get a Luk kit.
Old 05-08-2012, 04:13 PM
882tank's Avatar
882tank
882tank is offline
Luk, Hays, or even FoMoCo. Always spend the money and buy quality parts the first time.
Good Luck.
Old 05-08-2012, 08:48 PM
rangergirl94
Yea I screwed up I was on a tight budget
Old 05-08-2012, 09:46 PM
SideWinder4.9l
Installed is self explanitory.....Whether paid, or by myself...
If I'd have paid for it...I'd have listed it as a PAID installation...
Old 05-08-2012, 10:01 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
i hear center force has some serious stuff
Old 05-08-2012, 10:34 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
My buddy uses a center force in his pulling truck. It definitely grabs like nothing else I've ever used.
When I replaced the clutch in my truck I got whatever severe duty kit that Carquest sells. I will say that I'm not overly impressed with it, but it doesn't slip or anything with a load behind the truck or when I pull out stuck vehicles so that's a plus.
Old 05-08-2012, 11:37 PM
SideWinder4.9l
Centerforce is HD towing/Racing...So yea...They're serious...And serious $$$ too...
IIRC...A M5OD clutch kit from them was a mere $450...
Quick Reply: Anyone running duralast clutch kit on a work truck?
