Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-07-2012, 06:14 PM
PStruwing's Avatar
PStruwing PStruwing is offline
1997 Ford E-Series Van
My Garage
PStruwing is starting off with a positive reputation.
Question Flat Head ID Help
Hello all.
I am usually hiding in the E-series forums and have owned a few Y-blocks, Windsors and Mods.
Now I have an opportunity to pick up some flat heads from an estate sale and I have no idea what they are. Can you help from the pics?
Click the image to open in full size.
Thanks for your help in advance.
__________________
89 5.0 Mustang
97 E-150 Starcraft High Top Conversion Van
2002 F-150 XL - Nuked rear end!
1956 Meteor Wagon the car I should not have sold. Built in Oakville Ontario Canada, EH!
  #2 (permalink)
Old 05-07-2012, 09:26 PM
f5fordgirl f5fordgirl is offline
Garage is empty, add now
f5fordgirl is starting off with a positive reputation.
The first one is a 59-AB, second is an 8BA, its got head studs with nuts, if its got pet ***** behind the water pumps its a 48 model, first year in the trucks. Third looks to be a later ohv 4 cyl of some sort.
  #3 (permalink)
Old 05-07-2012, 09:32 PM
PStruwing's Avatar
My Garage
f5fordgirl, you rock! Thanks.
I am assuming the first two are runners as they are on test stands, sorta.
If I can get them for a good price they will make for good project motors. Just need to find the projects now!
__________________
89 5.0 Mustang
  #4 (permalink)
Old 05-11-2012, 07:32 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe is gaining momentum as a positive member of FTE.
The first engine may not be a 59A (1946-1948) motor. In the picture I cannot see a 59 cast into the bell housing. The radiator it is attached to looks like a 1938-1939 pickup / truck radiator. The generator mount fan is definitely 1939 or older, but the transmission is 1940 or newer. For a definite identification on the first motor look here: http://www.goldengatev8.org/tips/Evo...heFlathead.pdf
Also, DO NOT put the earlier motor on a modern engine stand supported by the bell housing. The 8BA is fine, but I have seen several earlier motors with the bell housing broken off from using incorrect engine stands.
  #5 (permalink)
Old 05-14-2012, 11:07 AM
PStruwing's Avatar
My Garage
Thanks for all your help but they all went for too much. The first motor went for $1000! And it would not run, so who know what is inside.
Too much for possible toys.
__________________
89 5.0 Mustang
  #6 (permalink)
Old 05-18-2012, 04:20 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a very good reputation on FTE.tinman52 has a very good reputation on FTE.tinman52 has a very good reputation on FTE.tinman52 has a very good reputation on FTE.
Just for curiosity sake, that engine in the bottom pic is for an IH Farmall tractor.......
__________________
Scott
'99 F250 SD 4x4
'62 F100 4x4
'52 F-1 "old blue"
My COE build thread;
http://www.ford-trucks.com/forums/11...uck-build.html
  #7 (permalink)
Old 06-09-2012, 03:48 AM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
I just want to say th advice from 38 coupe is exellent, couldnt have said it better.
__________________
Some nights you just have to realize your gonna be slaying a Dragon and not saving the Princess
  #8 (permalink)
Old 07-01-2012, 05:26 PM
fordmaan fordmaan is offline
1953 Ford F1
fordmaan is starting off with a positive reputation.
How do you post pictures, I have a 53 with a flat head in it and would love to find out what model it is or year even. also it has been sitting outside for 10 years(i know) in the truck still but{i still know} what would you do first before starting it as it did run when i originally bought it
Tags
1946, ab, f1, fan, flat, flathead, ford, head, identification, motor, put, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
