Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-07-2012, 02:47 PM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
Which Spark Plug Socket?
Looking to change my plugs tonight and wanted to know what socket you guys recommend. I didn't know if there is a better one for theses plugs. Thanks.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #2 (permalink)
Old 05-12-2012, 10:15 PM
gwells89 gwells89 is offline
2008 Ford Expedition
gwells89 is starting off with a positive reputation.
depends on engine born on date
Shouldn't be a problem on 08 but double check the engine build date. Should be on the engine and can be read on the left hand cam cover information sticker. If engine build date after 11/30/07. Then you dodged a bullet. If engine built before then, research like I did for proper precautions to prevent the two piece plug from breaking in the head. I didn't have the engine build date info until I had spend a week looking up how screwed I thought I was. Otherwise I bought an OTC 6900 Ford F-150 Spark Plug Socket and have 3" and 6" extensions handy. I had all eight changed in about an hour. Most places I read said to ensure the engine is fully cooled off before changing the plugs. As usual check the gap. Can't remember what it was. I used 8 Motorcraft SP-509 Spark Plugs off of amazon at $11.60 ea. I made sure that the seller had positive packaging reviews because they can be damaged in shipment. Hope it helps.
  #3 (permalink)
Old 05-14-2012, 11:55 AM
berry1234's Avatar
Awesome info! Thanks. I do have the newer style plugs-brown boot. I got out 4 of the plugs. Not much effort. Waiting to do the 4 harder ones after I get some more extensions u-joint type adapters. The old plugs looked pretty good for having 100K miles on them. Thanks for the input.
__________________
  #4 (permalink)
Old 05-14-2012, 06:36 PM
Yeah I forgot about the knuckle adapters. They are worth weight in gold for the spark plug change out. Especially the ones close to the fire wall. good job.
  #5 (permalink)
Old 05-22-2012, 08:34 AM
giants17068 giants17068 is offline
giants17068 is starting off with a positive reputation.
engine code
Not to high jack this thread but I recently discovered some disturbing info with my 2007 expy limited. I was expecting to have the long plugs that everyone has breaking off, however when I removed a plug it was a 5507 or NGK PZNAR6A11H. That seems awesome however everything I can find says these plugs are for a 2008 expy with brown boots. However, I have a 2007 with black boots?????? I have called ford and they have no record of my motor being swapped. So now what?? Thanks for any advice.
Tags
06, 1977, 2005, 302, 49, 87, escape, expedition, f150, f250, ford, plug, plugs, size, socket, spark, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
