AC compressor on 351m question
Old 05-07-2012, 06:10 AM
Roelito78's Avatar
Roelito78
Roelito78 is offline
Hello guys,
Yesterday, I decided to replace my ac compressor on my 79 F150. After the compressor, drier were installed and all my lines cleaned out I began to recharge my system with freon. As I started my ac as soon as the ac clutch would kick on my truck would die. I also noticed high pressure on my guages like there is a restriction somewhere. Like I mentioned I did clean out all the lines. One thing I did notice is that the compressor came with oil from the parts store but I had already added 8 oz extra without knowing. Could this be the problem? I managed to get rid of some of the oil by deppresuring the system but not sure if I should drain ut all and start over. Any advise? Thanks
Old 05-08-2012, 12:55 AM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
I'm no A/C expert, but it sounds like you've got too much oil and it's causing your compressor to hydraulically lock up. I'd drain the oil and start over.
Old 05-08-2012, 04:18 AM
Roelito78's Avatar
Roelito78
Thanks! Will do
Old 05-08-2012, 05:41 AM
ChiefM's Avatar
ChiefM
ChiefM is offline
Did you check the orfice tube?
Is this a NEW compressor?
8 OZ is alot but most of the excess should be sucked up by the desicant in the drier.
Old 05-08-2012, 05:43 AM
Roelito78's Avatar
Roelito78
New compressor and did not check the orifice tube. Is there anything I need to check in particular? Thanks
Old 05-08-2012, 05:51 AM
Roelito78's Avatar
Roelito78
I did notice that when the system was deppresured and some of the oil removed the truck did not stall anymore when the ac was turned on. Now the only problem is high pressure on my ac guages while trying to charge system.
Old 05-09-2012, 07:04 AM
ChiefM's Avatar
ChiefM
ChiefM is offline
The orfice tube is like a filter and can get clogged. It should be in the hard line going into the evap. I think. Never had to change one. YET.
jake22si
1997 - 2003 F150
06-28-2015 09:04 AM
p8ntballa9362
1997-2006 Expedition & Navigator
05-18-2009 03:02 PM
302VAN
04-03-2008 03:22 PM
Psycho Sasquatch
08-31-2007 11:55 AM
Quick Reply: AC compressor on 351m question
