Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 05-06-2012, 06:29 PM
GRIMJEEPER GRIMJEEPER is offline
Garage is empty, add now
GRIMJEEPER is starting off with a positive reputation.
78 F150 rides like a tank! HELP!
78 F150 351m 4x4 C6/203 stock suspension. any suggestions? Although I would like to lift it 2-3 inches in the front to level things out a bit.
Mike
  #2 (permalink)
Old 05-06-2012, 06:31 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
It's an old pickup.
  #3 (permalink)
Old 05-06-2012, 06:33 PM
that, my friend is not the answer I was looking for...
I belive it rides rougher than my 79 3/4 ton did. that was 15 years ago
  #4 (permalink)
Old 05-06-2012, 06:52 PM
Blue and White Blue and White is offline
Blue and White is starting off with a positive reputation.
How are the shocks and tires? Tire pressure? For running light 35 psi should be OK with stockish size tires. Less with wider/taller tires.
  #5 (permalink)
Old 05-06-2012, 08:15 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
1973 Ford F-100
My Garage
HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.
Quote:
JBG sells a 2-inch leveling kit for these rigs:
http://broncograveyard.com/bronco/i-...-bushings.html
JBG also sells soft ride leaf springs but it will result in a 4-inch lift. Alternatively, you could work with Eaton springs and have'em make a custom set.
Opt for hydraulic shocks instead of gas charged
  #6 (permalink)
Old 05-06-2012, 09:05 PM
meborder's Avatar
meborder meborder is offline
meborder has a great reputation on FTE.meborder has a great reputation on FTE.meborder has a great reputation on FTE.meborder has a great reputation on FTE.
i'd look for are a siezed up shock ... simple bounce check should find one if it is.
other than that, some guys install overloads and set them so the truck rides on them all the time .... that'll make them ride like poop! (Ask me how i know)
__________________
Work Horses:
2004 F250 SD SCREW; V10, 4R100, 3.73's
2000 Explorer XLT; 5.0 V8, 4R70W, 3.73's
1979 F350 Trailer Special; 460, C6, 4.10's
http://www.ford-trucks.com/guidelines.html
Tags
78f150, 97, expedition, fit, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
