SUPERCHARGE MY DIESEL - Ford Truck Enthusiasts Forums
Old 05-06-2012, 04:24 PM
JustiniantheGr8's Avatar
JustiniantheGr8 JustiniantheGr8 is offline
JustiniantheGr8 is starting off with a positive reputation.
Exclamation SUPERCHARGE MY DIESEL
ok i know u guys are all about the turbos, im not worried about fuel efficiency or power loss, its a show truck. i would really like to get a oldschool supercharger for my 6.9idi oldschool truck. so that being sed, anybody got any input on what to use and or where to get it
thanks for any input that doesnt invalve trying to sell me on turbos. (i allready know there better, thats not the point here)
Old 05-07-2012, 12:16 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I think you will be almost 100% on your own. Can you weld good enough to make yourself an intake manifold out of aluminum tubing?
I know what you're talking about--nothing looks quite like a big bad blower on top of a motor. An 8-71 or 14-71 would make that old dog bark....but it just isn't going to come out of a box.
Sorry, this dream is pre-crushed imo.
Old 05-07-2012, 08:50 PM
im a fabricator for cummins engine, so im good on that. i really just need starting point and general direction to go with it.
Old 05-07-2012, 11:45 PM
OK, how about this. Check the dimensions of your motor. Compare them to the larger gas motors that you know you can get a blower manifold for. (FE, 385 & 335 Fords, BBC, Hemi, etc)
http://blowerdriveservice.com/cart/ymm.php?cat=9_64
Looks like there is no water in your intake. That's a bonus.
http://www.google.com/imgres?q=ford+...9,r:2,s:0,i:78
Once you find a manifold that will sit between your heads and that is close as far as bore spacing, make adapter plates like the plates that allow a 351C manifold to be used on a 351M/400. Just a flat plate, cut at the angles needed with holes angled from the manifold port to the head port. You could do it in your back yard with a drill and a file....
OR you could marry that intake to part of a stock 6.9 intake.
Measure your crank snout and see if it's the same as any blower pulleys for any of the above engines. Have one made if not. You'll have to figure out accessory drives along the way.
Find out if you can crank up your injector pump, or get larger injectors.
There's more but I can't think of it now.
Old 05-08-2012, 09:37 AM
now thats more better, i can work with that. thanks for the heading.
Old 05-15-2012, 11:58 AM
AzPatMan's Avatar
AzPatMan AzPatMan is offline
AzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud of
I could swear that I saw Banks doing a Roots-type blower build on 6.9/7.3 recently somewhere. I'll see if I can't find it again.
Old 06-20-2012, 10:01 PM
bad a$$ roth bad a$$ roth is offline
bad a$$ roth is starting off with a positive reputation.
when i had my 7.3 thats exactly what i wanted to do....i really wish i coulda done it but please do this and support with pics. as far as advice id shoot for an 8-71 and build it like a gasser, custom headers, bigger valves,hybrid 466 injectors and look into ur timing and valve train, a supercharger might take ur heads off with the constant flow. unless u changed ur internals ur starting with 21.5:1 compression (unless its an 83which is 20.5:1) ive seen stock 7.3 run 15psi boost with no major problems and 6.9s will handle more for sure, head studs are gonna b a must and a bottom end girdle would b insurance,definantly gonna want to drop ur backing plate and run an allison or eaton tranny so mayb look into onboard air, thats wat i remember now. i really want to see this done on an idi.
Old 06-21-2012, 11:49 AM
AzPatMan's Avatar
Well, i found 1 article - but it's for the Bank's supercharging a duramax.
For anyone that's interested:
Banks Power | Banks Sidewinder Dragster Gets More Power
Old 06-22-2012, 12:05 AM
Cool article, but the writer makes an error on the HP/Torque. You can't have equal HP and torque at 6500 rpm. The HP/torque formula has the numbers equal only at 5252 rpm. Thus, if it makes 1500 ft/lb at 6500 rpm, it is making 1856.4 HP. If it is making 1500 HP at 6500 rpm, it is making 1212 ft/lb.
Those pistons remind me of my dad's 1957 Allis Chalmers WD-45. "Power Crater" is what AC called that design. Makes sense.
Old 03-10-2013, 01:14 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
u will want to shave .030 of of the pistons to drop compression..valve timeing very imprtant in diesel engines, with turbo's ,IE backflow, ect useing a super will open area's to think about,,u can over drive and use a waste gate to control boost..eary 6.9's had poor head bolts.. mounting will be difficult as it will block access to ip..it's a possibal maybe..
Old 03-10-2013, 08:20 PM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Heres 10 pages worth of info from a VERY smart man supercharging his Bronco w/ a 6.9. Hes also NOT lowering compression
http://www.ford-trucks.com/forums/11...thread-10.html
Old 03-10-2013, 08:30 PM
OP had another thread, and in there is a link to an oilburner site with a long 7.3 SC thread:
http://www.ford-trucks.com/forums/11...charge-me.html
SUPERCHARGE ME JustiniantheGr8 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 05-07-2012 10:14 AM
Question for the old-schoolers... Udo 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-28-2010 02:45 PM
Good mechanic for an old truck? Kynetx Washington Chapter 4 02-21-2008 11:38 PM
Super-diesel? scottie2hottie Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-24-2005 05:34 PM
Spreader bar on an F1?? 8Flat 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-29-2004 12:52 PM
Tags
1471, 2003, 69idi, 73, blower, cummins, diesel, f250, f350, idi, roots, supercharge, supercharged, supercharger, supercharging, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
