Advice on hub nut / bearing retainer. - Ford Truck Enthusiasts Forums
Old 05-06-2012, 02:24 PM
jimbo285's Avatar
jimbo285 jimbo285 is offline
jimbo285 is starting off with a positive reputation.
Looking for an opinion here concerning the D44 and D50 (F250) front hub bearing retaining nut washer assembly. My stock 94 Bronco and Stock 96 F250 front axles have the "double nut with multi-hole washer sandwiched between them" type retainer. Is there a better system out there that will work in each of the axle hubs? I have seen a one piece ratcheting nut assembly for other model years or even other makes, but I'm not sure if they are better or even available in my D44 or D50 setup. I've also seen some different systems advertised on "power block" on Spike TV. What do you guys think?
Old 05-06-2012, 07:57 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Im not 100% if im thinking of the same thing but is this what your looking for??
4-Prong WHEEL BEARING SPINDLE NUT SOCKET TOOL dana 44,fits many 4x4 front axles | eBay
I had to buy one when I was changing my rotors. They should have them at any auto parts store
Old 05-06-2012, 09:32 PM
jimbo285's Avatar
Yep, that's the tool to remove and install the nuts, but I'm looking to see if there is a better nut system. I don't know if I trust the current 2 nut and washer system used. The pins on the inner nut don't seem strong enough to hold the torque. Maybe it's just me?
Dana 50 green_95 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-20-2016 03:54 PM
How to replace ball joints/front u-joints zxwut? 1987 - 1996 F150 & Larger F-Series Trucks 33 01-04-2016 01:00 PM
Wheel bearing HELP! WHAT AM I DOING WRONG!?? Notpilbrisk 1994.5 - 1997 7.3L Power Stroke Diesel 3 06-16-2013 08:15 PM
Dana 44 Hub/Bearing/Axle/Balljoint Replacement Kirbys73F100 Clutch, Transmission, Differential, Axle & Transfer Case 5 05-23-2013 02:06 PM
Wheel Bearing Adjustment Procedure Rocky Mountain F150 1987 - 1996 F150 & Larger F-Series Trucks 12 09-11-2012 08:55 PM
Tags
1996, 4x4, 86, 94, axle, bearings, bronco, diesel, f250, ford, front, hub, nut, suspension, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
