Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 05-06-2012, 11:36 AM
Hua_7 Hua_7 is offline
Garage is empty, add now
Hua_7 is starting off with a positive reputation.
40/20/40 broke??
Im hoping someone could help me solve my issue. I have an 09 f250 with the 40/20/40 bench seat and when I have the center folded down it feels like the passenger side of it is broken and it rocks back and forth. I can't seem to get the center apart so I can see what's going on. Anybody know how to fix this?? Thanks
  #2 (permalink)
Old 05-06-2012, 12:58 PM
06 CC 250's Avatar
06 CC 250 06 CC 250 is offline
2006 Ford F-250
06 CC 250 is starting off with a positive reputation.
im going to try to explain how to fix it, it has been a while since i fixed mine and im not looking at it now so i will do the best i can.
where the fabric (or leather) goes up and folds over the top of the console there is a plastic keeper ring snapped on, to keep the cloth in place. you will need to pry that out with a flat head screw driver, be very careful or it could break.
when you get that keeper out of the way just pull the fabric down in the back (on the passengers side) and you will probably see a screw laying in there somewhere that has come loose. it goes up through a metal bracket and screws into the plastic part of the console. you could probable even use some epoxy or plastic weld on the screw before you put it back to keep it from loosening again.
then just lift the fabric back up in place, keep it tight when putting the keeper back on so it wont be loose. its kinda a pita to do, but just take your time. and if you have the CC its easier to do in the back seat. hope this helps out.
  #3 (permalink)
Old 05-06-2012, 03:56 PM
Awesome thank you. I was prying on that ring a little, but I wasn't sure.
  #4 (permalink)
Old 05-06-2012, 08:53 PM
Biscayne Biscayne is offline
Biscayne is starting off with a positive reputation.
Man.....I just figured this out on my own tonight. I wish I had seen this earlier. For anyone else that has found this thread.....it works on a 2002 as well.
__________________
2000 F-350 4WD CCSB, bone stock 7.3
Mama's 2009 Expedition EL 4WD
2002 F-250 4WD Extended Cab --sold
2001 F-250 Crew Cab 2WD -- sold
2001 F-250 4WD Extended Cab--Sold
  #5 (permalink)
Old 05-06-2012, 10:32 PM
Finally tore into it and it's all fixed. Pretty easy and it's just one dumb screw. Thanks again
  #6 (permalink)
Old 09-26-2012, 02:41 PM
Amosmoses33 Amosmoses33 is offline
Amosmoses33 is starting off with a positive reputation.
Would it be possible for someone to post a pic of this ring to pry up?
  #7 (permalink)
Old 09-26-2012, 09:05 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a good reputation on FTE.Bigpipes 35 has a good reputation on FTE.Bigpipes 35 has a good reputation on FTE.
Quote:
Hey Biscayne any chance you could post a few pics on how you got your console apart ? I have an 03 and cant figure out how it comes apart.
__________________
2003 F250 fx4 cc short box. 5.4 , 4.30 gears, flowmaster 50 , spd Y pipe , eagle alloys , 285/70/17 nitto terra grapplers, SCT X3 tuned , warn manual hubs, 6.0 trans cooler mod
2000 f150 4x4 work truck 4.6
  #8 (permalink)
Old 09-27-2012, 08:26 AM
I figured it out...wow, pretty easy. I ended up taking the storage compartment door off by sliding wire pegs out the hinges (have to let the seats back) Just start on the passenger side and put a flat head in and pry towards the door and up. The "holders" are towards the inside. I'll take a pic tonight, I didn't think of it as I was doing it. Sure enough, the screw was laying in there. I added a small washer to it. Turns out I still have a crack that is giving it some very slight wobble, but I am sure it will get bigger and bigger.
  #9 (permalink)
Old 09-27-2012, 09:02 AM
Quote:
Hey Amosmoses , what year is the truck you fixed?
__________________
  #10 (permalink)
Old 09-27-2012, 09:04 AM
Its a 2008 F-250.
I think they are all the same though. Mine is not a bench though, its two captain chairs with the jump seat in the middle. The principal is the same though as the armrest is the same.
  #11 (permalink)
Old 09-27-2012, 09:52 AM
Its a 2008 F-250.
Sounds good I will tear into it tonight. Thanks for the info
__________________
  #12 (permalink)
Old 09-27-2012, 09:58 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.
my 04' did this but the plastic itself cracked, i cut a small piece of aluminum angle and pop riveted into the insie. it looks like hell when i open the top but i did paint it black before i installed it but two dollars for the fix is better then 300 for a new center seat
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ TransGo HD shift kit, 4.30 gears w/ stock LS, SCT X3, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
  #13 (permalink)
Old 09-27-2012, 01:52 PM
Ok, here are the pictures. I didn't take anything apart but I am showing the "ring" you have to pry up to get to everything. I am using my facebook, maybe this works. If not I can email them and someone can put on pic sharing site.
In this one, its the piece between my fingers.
Click the image to open in full size.
In this one, its the piece that borders the fabric. The fabric actually tucks up under this. I was only able to really pull it out from the back versus the sides. But the back is where the screw is so thats okay.
Tags
402040, 97, broke, f250, fix, seats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
