Wheel Stud Size Changable? - Ford Truck Enthusiasts Forums
Old 05-06-2012, 11:31 AM
Built_Ford_Tough_757's Avatar
Built_Ford_Tough_757 Built_Ford_Tough_757 is offline
Built_Ford_Tough_757 is starting off with a positive reputation.
My 1985 F350 has the factory 10 1/4 steerling with 9/16 studs. The front is sporting a 1979 F250 Dana 44 HD, the rotors have 1/2" studs. I guess my question is, are all openings for the studs the same? so the size of the stud can be swapped? I've looked for front rotors with 9/16 stubs but didn't have much luck. I don't care which size is used on my truck, I just want all them to match.
Old 05-06-2012, 11:39 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
AFAIK yes, the hole sizes are all the same. AFAIK but YMMV.
Seriously... I had to replace some studs on my '81 F350 once, don't remember if front or rear, but I went to the auto parts store where they pulled out one of those multi-compartment organizer boxes that had all kinds of different size studs in it. It looked like they all had the same base size, the differences being in the thread size & length.
Call up a parts store and see what they have....
Old 05-06-2012, 11:52 AM
Cool, Thanks for the quick reply.
Replacing new hub/rotor assembly from 9/16 studs to 1/2 studs Jlongwell1 Brakes, Steering, Suspension, Tires, & Wheels 8 10-18-2015 07:24 AM
'78/'79 Dana 60 Studs size from 1/2" to 9/16' 79Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-04-2015 04:49 PM
lug nuts and studs brian1080 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-15-2014 02:40 PM
Can anyone help wheel stud problem gomer450 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-11-2013 08:20 AM
wheel stud size D8chumley 1987 - 1996 F150 & Larger F-Series Trucks 2 01-15-2007 04:38 PM
Tags
1986, 2003, 2005, 350, chart, davidson, diameter, f150, f250, ford, harley, lariat, size, sizes, stud, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
