PTO - Power Take-Off Question
The net result is, a standard, AC powered compressor will not perform well on a commonly available inverter, for reasons beyond what is discussed here, beyond even the 'surge' factor.
and for what its worth, i'm using a relatively cheap harbor-freight inverter
IMHO "without getting technical" - here it is in a nutshell.
Remford was "afraid (his) van (with 225 amp alternator & 2 batteries) can't provide enough electrical power to meet any such compressor's starting wattage requirements". He didn't worry IF his van can "provide enough electrical power to meet any such compressor's" much lower "wattage requirements" once running at speed.
Again "without getting technical" or having to "pigeon hole...common belief" we haven't see any reason why "just this kind of system"..."will not perform well" ENOUGH. No, it's not very efficient. It's a convoluted system & suffers lots of energy loss. After all, we're talking about using a V8 to power a 1-2 hp AC compressor.
Almost makes me want to suggest 1 of those antique 'Spark Plug' compressors. Ever seen one? A little Emergency Kit designed to carry in glove box, to inflate a flat tire. Consists of a length of hose long enough to reach from motor to furthest tire. One end has special check valve fitting w/spark plug threads, the other a tire valve chuck for inflation. Idea is to remove 1 spark plug & install 'kit' so that cylinder works as compressor.
I do know that you can replace a non-PTO trans in an E series with a PTO trans.
Johnzan
24
02-25-2015 07:53 PM
995.4SD
10-02-2013 09:58 PM
Boo_Daddy
04-20-2011 01:03 PM
JonathanN
1999 to 2016 Super Duty
09-19-2010 08:59 PM
nuthinbutfords
Modular V10 (6.8l)
07-21-2010 09:13 PM
