fuel pump problem - Ford Truck Enthusiasts Forums
fuel pump problem
Old 05-06-2012, 10:44 AM
jwilly53 jwilly53 is offline
jwilly53 is starting off with a positive reputation.
fuel pump problem
I just finished getting my 65 f250 back together and found I'm not getting any fuel delivered to the carb, I replaced original tank with a Bronco II tank mounted under the bed . has anyone had problems with the original pump pulling from a relocated tank?
I've put my Mighty-Vac on fuel line at the pump and it pulls fuel from tank OK ,but when I put it on line at the carb I don't get fuel.I replaced the pump with a new one but still no fuel. Is there something I'm missing? do I need to prime the pump somehow?
any info is greatly appreiciated.
thanks , Joe
Old 05-06-2012, 12:39 PM
KO1960 KO1960 is offline
KO1960 is starting off with a positive reputation.
Old rubber lines, and a fuel filter between the pump and carb can cause problems. What engine do you have? Feed the pump from a gas can to test the pump. If no gas, then the pump could be bad or the pump arm is not engaged. No priming required. Good luck.
Kurt
Old 05-06-2012, 03:01 PM
Kirk,
I replaced the fuel pump with a new one from A-Zone along with new filter, still nothing, when I put my vacuum pump on the line to tank I get fuel, was wondering if the original pump had enough suction to pull fuel from the tank located at the rear of my frame. the original pump work fine before I torn the truck apart to restore - about 3 years ago but the tank was located behind the seat then. It's got the 352 motor in it.
was wondering if anyone else that move their tank to the rear had similar problem.
thanks
joe
Old 05-06-2012, 06:30 PM
Joe, you need to isolate the tank from the pump to determine if the pump is working properly. Some here have had problems with aftermarket pumps. The tank relocation isn't something that I can speak to. Hopefully, someone with the experience you are looking for will chime in. Good luck.
Kurt
New fuel pump not getting fuel Speedymaru 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-21-2016 10:16 PM
Installed new gas tank, now won't start brokersteve 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-18-2013 05:02 AM
351m fuel pump problem tom42nm 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-11-2012 10:04 AM
Next Question Tedybear 1973 - 1979 F-100 & Larger F-Series Trucks 38 12-19-2007 12:34 PM
will not get gas to the carb . 1955effie 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 10-22-2006 04:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
