Has anyone used 2" lift shackles? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-06-2012, 05:05 AM
Linne's Avatar
Linne Linne is offline
Linne has a good reputation on FTE.Linne has a good reputation on FTE.Linne has a good reputation on FTE.
I am trying to figure out how to level my truck and now I have on solution, only need some measurements and comments on this:
I think I have a 2,5 to 3.5" lift kit in front and my front is lover then the rear
And I would like to level it to look better, is there anything that would make it a bad idea to put longer shackles to the rear of the front leaf springs?
What about wheel turning angles? would they stay okay?
I do not now how much lift I need to level it but if some one has ever used 2" lift shackles like this:
Ford Superduty 2" Front Lift Shackle Leveling Kit | eBay
What are the measurements how long are they and how long is stock shackles? I do not know if I have stock or not?
But it would be insane to buy a set fo $60 and shipping overseas to here to Finland another $60 when I have material and time to make my own shackles. It's about 20min work if I only get a measurement to start with
Old 05-06-2012, 06:27 AM
Linne's Avatar
I measured my own shackles to 17cm and using converter app to convert to inch it would be 6.69" long shackles,, that is measured from edge to edge and from center of the bolt holes measured it would be 12.5cm that's 4.9"
So if they are stock shackles how much longer should they be to work as 2" lift?
if only adding 2" length to the shackles it probably wont lift much an inch maybe?
Old 05-06-2012, 01:58 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
I run the same shackle on the front of my truck with no problems. I can get you a measurement in a few.
Old 05-06-2012, 02:51 PM
Linne's Avatar
Thank you! Appreciate it!
Old 05-06-2012, 10:32 PM
I apologize door the delay, had a super busy day today. I will measure them first thing in the morning.
Old 05-07-2012, 01:36 AM
Linne's Avatar
No hurry
Old 05-13-2012, 06:13 AM
Linne's Avatar
Quote:
Did you remember to take measurements?
Old 05-13-2012, 07:29 AM
Parts Jimmy's Avatar
Parts Jimmy Parts Jimmy is offline
Parts Jimmy has a good reputation on FTE.Parts Jimmy has a good reputation on FTE.
What does this do to the front pinion angle?
Old 05-13-2012, 08:00 AM
rbloodhound's Avatar
rbloodhound rbloodhound is offline
rbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud of
I ran them on my 04 F350. No problems with pinion angle. I bought mine off of ebay.
Old 05-13-2012, 10:26 AM
paul turner paul turner is offline
paul turner is starting off with a positive reputation.
I put a pair in yesterday. was a bitch on the 1st one. 2nd was easy...
paul
Old 05-13-2012, 01:25 PM
Linne's Avatar
So could anyone please paste some measurements on them?
I would also buy them on ebay if I lived in the US
but when I live in Finland and there is no where else to buy these than in the US the total price would be insane for me. The shackles are about $60 and the best shipping prices so far would be around $60 and then I pay 7.5% custom fees on total 60 + 60 = 120 + 7.5% = $129 and then I pay taxes 23% on that total, that would be 129 + 23% = $158.67
For that price I can make my own shackle at least 10 times, if I only had the measurements
Old 05-13-2012, 02:59 PM
So sorry, glad I saw this thread again. Mine a 10" long, 2" wide and 8" centers for the bolt holes. They are made of 1/4" flat stock with square tube in the middle what ever width your springs are. I even snapped a pic. Again sorry about the delay.
[IMG][/IMG]
Old 05-13-2012, 03:12 PM
Linne's Avatar
[IMG][/IMG]
thank you so much! you made my day
Old 06-02-2012, 02:31 PM
Linne's Avatar
I finaly had the time to make the shackles.
Now my truck looks level to me!
The extra holes are for stock height, It's only temporary that the holes are empty, I will put an iron pipe there with a bolt going through it that way it's easy to change it to stock when next years inspection comes.
Old 06-02-2012, 03:51 PM
Fosters Fosters is offline
Fosters is gaining momentum as a positive member of FTE.
Sweet looking truck. What happened to the swaybar?
Anyone have pics of a leveled regular cab? Esp one with stock or close to stock tires?
Lifted Kit Questions 0500757Arf 1987 - 1996 F150 & Larger F-Series Trucks 38 07-06-2016 10:05 PM
Lift and Level question (opinions needed) phlegm 1973 - 1979 F-100 & Larger F-Series Trucks 26 03-31-2016 11:32 AM
leveling spring pack vs. shackles hpcbmw 1999 - 2003 7.3L Power Stroke Diesel 9 01-15-2016 11:04 PM
leveling kit questions... (again) BioHazrdMan 1999 - 2003 7.3L Power Stroke Diesel 4 05-19-2015 11:10 PM
Which shackles to get for a lift? blackx psd Excursion - King of SUVs 3 03-25-2011 05:46 PM
Tags
2, 2004, 2in, 73, block, drop, excursion, f250, ford, front, inch, lift, liftshackle, shackle, shackles, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
