Has anyone used 2" lift shackles? - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 06-17-2012, 06:20 PM
FordGuy85's Avatar
FordGuy85 FordGuy85 is offline
FordGuy85 is starting off with a positive reputation.
Quote:
Originally Posted by Linne View Post
Thats interesting I had no problem to with moving everything by hand.
Yeah it does look much better my truck also looks about 200% better
Thanks for posting this thread
  #47
Old 06-17-2012, 08:48 PM
sand_fiend's Avatar
sand_fiend sand_fiend is offline
Work in Progress
sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.
I finaly had the time to make the shackles.
Now my truck looks level to me!
The extra holes are for stock height, It's only temporary that the holes are empty, I will put an iron pipe there with a bolt going through it that way it's easy to change it to stock when next years inspection comes.
The reason the other shackles had a square block welded in the middle is for stability. Longer shackles will let the front end sway a little. The welded block will help keep both pieces as one . it's like taking two pieces of metal and putting a bolt through both ends with the pieces 4 inchs apart .. the longer they are the more they will sway.. the block will not let then move independently and stops the sway on EACH shackle..
  #48
Old 06-17-2012, 09:05 PM
FordGuy85's Avatar
Quote:
I agree. At the very least, I would have maybe put a solid block in there with 5/8 taped holes in both ends. Would stiffen it up a bit and act like a middle support weldment.
Also on the other hand, if he is off road a lot of the time, he may want that extra flex.
  #49
Old 06-18-2012, 10:09 AM
Linne's Avatar
Linne Linne is offline
Linne has a good reputation on FTE.Linne has a good reputation on FTE.Linne has a good reputation on FTE.
I know I have now put a bolt through there and a round pipe in the middle, I was planning on tapping the ends of the round pipe and then drill a hole for the bolt that way I get the bolt in center of pipe as you can see in picture the pipe is a litle bit higher than the bolt.
I would also recommend to weld the square tube instead, I have no doubt about that beeing the strongest version.
  #50
Old 06-18-2012, 04:41 PM
FordGuy85's Avatar
Should be ok with grade 8 or better hardware.
Also one more thing I discovered after doing this mod. Before when i would turn I had some rubbing issues with the 35inch tall tires. They used to rub on the the inside fender well on the drivers side. Then on the passenger side, had some rubbing on the leaf spring. I can't figure out why but there is no more rubbing there.
  #51
Old 06-19-2012, 05:37 AM
Linne's Avatar
About the rubbing I noticed the same thing
  #52
Old 06-19-2012, 11:26 AM
FordGuy85's Avatar
I thought it was weird how the tire would rub passenger side leaf spring and not the other. I'm extremely happy with this mod so far. Before I found the thread, I was planning on getting the Rough Country shackle lift. ($330) I thought I needed the extended front (fixed) shackle that came with the lift. To be honest, I'm glad I don't have a extended front shackle. I might have been able to see it sticking down from the front of the truck.
  #53
Old 06-19-2012, 11:28 AM
Linne's Avatar
I'm glad that this thread was useful!
  #54
Old 04-01-2013, 05:52 PM
RUNVS's Avatar
RUNVS RUNVS is offline
RUNVS has a good reputation on FTE.RUNVS has a good reputation on FTE.
I have been thinking of adding the 4" block to the rear of my f250 (so it's same as F350) and then a shackle kit up front. Some say don't extend the shackles unless you extend the hangers as well.
I have the plow package so my front end sits almost level. that means a 2" rise in back should be 2-2.5" in front so the truck remains level.
Some of you guys definitely didn't add the hangers. That will definitely change your pinion angle. When you drop the back of the springs, you rotate the axle backward. This will affect the pinion angle and your caster angle as well.
Did anyone notice any negative affects? Anyone have any vibration or is anyone eating up U-joints?
Now, does anyone know if the brackets on a kit like the Rough Country kit have a different drop length on the hangers than the shackles in order to maintain the pinion angle?
Maybe 2-2.5" isn't enough to worry about these things??? You guys that have been running a shackle-only lift, what are your long-term findings? Anyone running a shackle & hanger lift?
  #55
Old 04-01-2013, 06:24 PM
Linne's Avatar
I think 2-2,5" lift is so small change that I would not worry about it, but yes all these angles will change a little
  #56
Old 03-01-2014, 10:17 AM
Grizzly4x4's Avatar
Grizzly4x4 Grizzly4x4 is offline
Grizzly4x4 is starting off with a positive reputation.
Here's a couple pics of the truck after I got the new shackles on.
Snapbucket :: Shackle picture by Fordguy85 - Photobucket
Here is how the truck looks now. %100 better.
Snapbucket :: After shackle lift was installed. picture by Fordguy85 - Photobucket
What size lift/tires is that? I seem to have about the same truck minus that and that's what I'm looking for.
  #57
Old 03-01-2014, 03:52 PM
knightrider955's Avatar
knightrider955 knightrider955 is offline
knightrider955 is starting off with a positive reputation.
I added the 2.5 inch shackles off of ebay and put them on over a year ago. I also plow and drive my truck 90 miles per day for work. No issues what so ever. No funny noises or broken U Joints. I didn't even change out my stock shocks. Only thing I noticed after the install is that my steering wheel is a little turned to the left when driving straight. I think its because my track bar is pulling my front end to the left side a little. I need to get an adjustable one and re center my axle. But it still drives fine and doesn't pull or anything.
  #58
Old 03-01-2014, 04:14 PM
Grizzly4x4's Avatar
Quote:
Was your's a 4x4? Any vibrations in 4wd?
  #59
Old 03-02-2014, 12:43 AM
Quote:
Mine is a 4x4. I plow with it. I drive 65 in 4x4 with NO issues
  #60
Old 03-11-2014, 08:29 AM
subysouth's Avatar
subysouth subysouth is offline
subysouth is starting off with a positive reputation.
I'd like to know this as well please FordGuy85.
ss
Lift and Level question (opinions needed) phlegm 1973 - 1979 F-100 & Larger F-Series Trucks 26 03-31-2016 11:32 AM
leveling kit questions... (again) BioHazrdMan 1999 - 2003 7.3L Power Stroke Diesel 4 05-19-2015 11:10 PM
Looking to add more lift! WhiteOut FX4 1999 to 2016 Super Duty 4 09-24-2013 03:03 PM
Shackle Flip?? Beast_250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-13-2013 06:20 PM
Can anyone tell me what brand spring hanger lift kit this is? viperbluelx 1999 to 2016 Super Duty 19 07-18-2007 10:55 AM
Tags
2, 2004, 2in, 73, block, drop, excursion, f250, ford, front, inch, lift, liftshackle, shackle, shackles, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
