Has anyone used 2" lift shackles?
#31
I am 100% sure that when towing big loads then it would have a big difference, but I never tow anything more than a passanger car on a trailer max...
Normal on road use I must say I have not noticed any difference.
#32
Edit: Oh one more thing. Does the extra length shackle look any kind of goofy form the side of the truck? I was trying to imagine it being longer but its hard to tell what it will look like when its finished.
#33
i had my front sway bar removed for almost a year and it handled the same before and after it was on or removed. I took mine off because i had to add poly bushings and just never added it back right away, it did help out while off road, i never knew my truck could flex that good before!
And drop shackles look weird from the side of the truck, you see the springs hanging down and that stupid spacer hanging. I have a picture of my 1" drop shackle ill post so you can see
#34
Also I just hought of another question to whoever made these shackles. Did u use regular cold rolled steel. Does the steel have to have any hardness to it? Was thinking the bolts might woller the holes out after a while.
#35
#36
Should work well. 8 inch between bolt centers. 5/8 drilled holes.the part will be 10 inches long overall by 2 1/2 width.
Just wanted to post what I'm doing for all to see.
#38
i too have the same shackles in front that provide lift. my issue is with my donahue lift and the shackle lift my front driveshaft doesnt fit and my pinion angle is A** as it comes out straight now no angle up at all? called the driveshaft shop they can lengthen shaft for $200.00 but is that angle gonna eat u-joints? also if it everyone thinks its gonna eat ujoints im gonna take them out and drop rear 2.5" with different blocks so it sits level?thanks
#40
Sounds good. I am going to use 3/8 thick flat stock because right now theres a 1/2 inch ectra bolt hanging out extra past the nuts. And 1/4 inch wall box tubing just like you described.
#42
Oh Yeah. I remember these pics now. Is don't see anything too bad here.
Actually that looks pretty good to me. Thanks for posting.
Here is a pic of one of the shackles I made yesterday.
Snapbucket :: Spring shackle. picture by Fordguy85 - Photobucket
#43
Ok I got the new shackles on the truck and everything looks really good. Had a little trouble getting the springs re centered to the shackles but I made a tool to push the springs back to center and it worked great.
Here is the tool.
Snapbucket :: Spring pushing press. picture by Fordguy85 - Photobucket
Before I made that tool, I couldn't get the springs to center back up. There was no way they were moving. I had a come a long, rachet straps, pry bars and everything else. Couldn't budge them.
The tool saved the day.
Here is the tool.
#44
Here's a couple pics of the truck after I got the new shackles on.
Snapbucket :: Shackle picture by Fordguy85 - Photobucket
Here is how the truck looks now. %100 better.
Snapbucket :: After shackle lift was installed. picture by Fordguy85 - Photobucket
#45
Here is the tool.
Here is the tool.
