Clean your radiator! - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 05-06-2012, 12:45 AM
ddivinia ddivinia is offline
ddivinia is gaining momentum as a positive member of FTE.ddivinia is gaining momentum as a positive member of FTE.
In the midst of upgrading the headlamps in my 2000 X I looked down between in front of the radiator. Man, it was pretty nasty in there. 4 clips and you can get in there and clean it up. I wish all vehicles made it that easy.
I used a long blow out tube attached to my air compressor. I use it to blow out of my hay baler and tractor radiators, etc.
Here are some pics.
D.
Old 05-06-2012, 07:56 AM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Nice work!! I'll have to check mine out!!
Old 05-06-2012, 11:02 PM
You should have seen the pile of crap on the shop floor after I blew it out. It was a pile.
D.
Old 05-07-2012, 03:45 PM
neilc88's Avatar
neilc88 neilc88 is offline
neilc88 is gaining momentum as a positive member of FTE.neilc88 is gaining momentum as a positive member of FTE.
Good thing to check with summer time temps on the way.
Old 05-07-2012, 10:53 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
they sell radiator combs for that purpose. Compressed air can actually bend the fins (from experience) if you get carried away. But its fine to use if you use a regulator to dial it down or just be careful.
Old 05-07-2012, 11:14 PM
kornfanjoe's Avatar
kornfanjoe kornfanjoe is offline
kornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant future
its all about the angle that you use when cleaning the radiator. at my shop we use pressure washers and a solvent to clean rads and we inspect for bent fins first then blast it at a direct 90* angle to prevent the fins from bending.
good job on noticing.
Last edited by kornfanjoe; 05-07-2012 at 11:16 PM. Reason: typical monday typo, wrote 45* instead of 90*
Coupler for radiator hose leading to throttle body? Built-Ford-Tough91 1978 - 1996 Big Bronco 4 03-07-2015 10:15 PM
The inside of my radiator; Stop-Leak, or hard water deposits? Golden Helmet Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-12-2014 01:14 AM
I need a new radiator lemonshindig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 12-04-2013 10:13 PM
Lower radiator hose question Jimmygunz3 1997-2006 Expedition & Navigator 9 12-06-2011 04:13 PM
Lime-A-Way to clean radiators Avanti Garage & Workshop 9 09-05-2002 02:34 AM
Tags
2000, 2010, 67, clean, cleaning, econoline, edge, f250, flush, ford, radiator, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
