Edge Insight CTS - Back-up Camera - Ford Truck Enthusiasts Forums
Old 05-06-2012, 12:12 AM
401-k 401-k is offline
401-k is starting off with a positive reputation.
I added the Insight CTS about a year ago and recently added a back-up camera.
It seems to switch back & forth between the gauges and the camera when in reverse. How can I set it to stay on camera when in reverse? Also, sometimes when towing I like having the camera on to see what is going on back there. How do I do accomplish the above?
Old 05-06-2012, 12:44 AM
TexasA&M's Avatar
TexasA&M TexasA&M is offline
TexasA&M is gaining momentum as a positive member of FTE.TexasA&M is gaining momentum as a positive member of FTE.
Mine seems to randomly switch back to gauges sometimes when I'm in reverse. It always goes back to the camera after a few seconds though.
As far as turning the camera on whenever you want to, when you go into the menu, the top option will be 'View Camera.' Just click this option and you'll see what the camera sees. You'll need to make sure that the camera is powered by something other than the reverse lights, otherwise you will only be able to use the camera in reverse (mine is powered by the 12v wire in the 7way trailer harness, thus it is on whenever the key is on).
adding factory backup camera to back of camper ProActive Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 7 07-05-2016 08:19 AM
stock backup camera upgrade expoman55 2007 - 2014 Expedition & Navigator 1 05-12-2014 12:41 PM
Back-up camera SniperVision 6.0L Power Stroke Diesel 6 06-05-2013 09:01 PM
08 Navigation and backup camera upgrade sredmyer 1999 to 2016 Super Duty 6 10-28-2011 01:07 PM
Backup Camera DIXIEDOG1 1999 to 2016 Super Duty 34 10-10-2010 03:23 PM
Tags
97, adding, back, backup, camera, cheap, cts, edge, f150, ford, insight, issue, rear, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
