90 f250
Old 05-05-2012, 09:24 PM
sheller's Avatar
sheller
sheller is offline
90 f250
Can my oil pressure switch cause the fuel pumps to not work? and if so where can i find the oil pressure switch?
Old 05-06-2012, 02:00 AM
882tank's Avatar
882tank
882tank is offline
No. Check your fuel pump relay and inertia switch.
Old 05-06-2012, 01:20 PM
sheller's Avatar
sheller
sheller is offline
I replaced the Fuel pump relay, EEC relay, and the inertia switch still with no luck. the funny thing is that the pumps on both tanks would turn on the night before but the next day they both stopped working. the fuel filter is clear so it has me thinking if the fuel lines are clogged.
Old 05-07-2012, 09:32 AM
94BigRed's Avatar
94BigRed
94BigRed is offline
Check the fuse in the panel under the hood. I had a wire get rubbed bare and short out my tanks and blew this fuse. I dropped both tanks and swapped switches before I thought to check here.
Old 05-07-2012, 11:39 AM
sheller's Avatar
sheller
sheller is offline
I was unable to find the fuse panel under the hood i have one under my dash drivers side. i changed all those fuses.
Motosk813
31
11-27-2017 05:57 PM
MIKE861943
09-12-2017 08:51 AM
sgtdunk1973
06-28-2014 01:04 PM
matthnatow
07-13-2008 03:06 PM
kpowers62
1983 - 2012 Ranger & B-Series
10-15-2002 02:03 PM
Quick Reply: 90 f250
