Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-05-2012, 01:58 PM
kf1128 kf1128 is offline
Garage is empty, add now
kf1128 is starting off with a positive reputation.
Starts, runs, dies after 20 min
Have a 1960 f250 with a 223. Truck will start and run fine for 20-30 min and then it dies. Will eventually restart, sometimes not till the following day. Also seems to getting pretty hot. Cleaned fuel filter and put on rebuilt carb. Any thoughts would be appreciated.
  #2 (permalink)
Old 05-05-2012, 02:46 PM
AndyZell's Avatar
AndyZell AndyZell is offline
AndyZell is starting off with a positive reputation.
check the fuel line that runs in the tank. my 60 f100 did that for a while till i cleaned that line. and also pressurize the tank periodically by blowing into the filler spout to get a good stream of fuel getting in the lines. and if its getting hot you might have some air in the cooling system i would try burping it to see if that helps.
  #3 (permalink)
Old 05-05-2012, 03:11 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
First thing I'd do is see whether it lost spark or fuel when it died. There are some pretty simple diagnostic steps we can walk you through to avoid the old "let's throw new parts at until it's fixed" method.
  #4 (permalink)
Old 05-05-2012, 03:53 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
The coil could be getting hot and opening up but I would tend to lean toward feul line/fuel tank/filter stuff.
As was mentioned, tell us what it is doing or not doing when it quits. They are a fairly simple engine to work thru.
  #5 (permalink)
Old 05-05-2012, 03:56 PM
AndyZell's Avatar
i have a question. when it dies is there fuel in the filter?
  #6 (permalink)
Old 05-05-2012, 05:25 PM
Thanks for all the replies. There is fuel in the filter when it dies. Just checked and there is currently no spark, started and ran for 20 min earlier today.
  #7 (permalink)
Old 05-05-2012, 06:02 PM
MARC's Avatar
MARC MARC is offline
1959 Ford F-100
MARC is starting off with a positive reputation.
sounds like hot coil, 10.00 part at local auto parts store
  #8 (permalink)
Old 05-05-2012, 08:01 PM
AndyZell's Avatar
yup most likely the coil
  #9 (permalink)
Old 05-05-2012, 11:01 PM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
Quote:
I agree with
  #10 (permalink)
Old 05-06-2012, 05:15 AM
spurredon's Avatar
Could also be some other connection that is corroded and vibrates apart while it is running. Later after it sits, it can touch just enough to run again. Where the harness plugs into the firewall is a perfect place for something like that to occur. I did mention the coil earlier but they often get the blame first. Then you have to spend the time to find the real problem.
  #11 (permalink)
Old 05-06-2012, 10:28 AM
If you don't own a test light, go buy one. Start checking for voltage at the coil + with the key on. If there isn't juice there then backtrack to the switch. If there is juice at the coil + and you have no spark, check for juice right at the points, they will have to be open for it to light up. Also on the wire to the points, the coil -, it should blink the light if you check while the engine is cranking.
I'd like to find those $10 parts store coils, last one I bought was more like $40.
  #12 (permalink)
Old 05-06-2012, 10:38 AM
MARC's Avatar
1959 Ford F-100
ok..ok..ok, I admit it has been years since I had to buy a coil... now 25-30 bucks
  #13 (permalink)
Old 05-06-2012, 07:32 PM
spurredon's Avatar
Quote:
Give China time to get the price down, they already have the quality down to $10!
  #14 (permalink)
Old 05-06-2012, 09:13 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Sometimes the truth is funny even when it hurts!
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
Tags
05, 10, 20, air, cooled, dies, diesel, engine, f100, ford, good, min, quits, runs, starts, wisconsin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
