Gear oil - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gear oil
Old 05-05-2012, 01:49 PM
renoduckman renoduckman is offline
renoduckman is starting off with a positive reputation.
Gear oil
What gear oil is supposed to go in my rear diff in my 02 F250? I am 99% sure i have the non limited slip standard rear end. My truck is at about 109k and i just realized i have never changed it. Joe
Old 05-05-2012, 02:21 PM
david0505 david0505 is offline
david0505 is starting off with a positive reputation.
Hi Duckman,You might want to look at the "motorcraft axle lubricant" website,lots of good info....Dave
Old 05-05-2012, 02:45 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
The Sterling 10.5 specs 75w140 gear oil. I used Amsoil Severe Gear because I have an account with a vendor that sells it. Works well and is about the same price as a lot of other 75w140 oils. Best to not add any friction modifier unless you experience chatter.(only applies to the limited slip diff obviously)
Old 05-06-2012, 01:50 PM
oil
Yes thanks men. Found my missing owners manuel and it does say 75-140 oil. Thanks
Old 05-06-2012, 03:31 PM
Baddestt Baddestt is offline
Baddestt is starting off with a positive reputation.
I've used the 75w110 amsoil severe gear lube, a tick better fuel mileage.
Rear differential gear oil 66with352 1997 - 2003 F150 1 10-28-2016 09:54 AM
Dana 60 gear oil replacement? Old Brown F250 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-16-2013 11:36 PM
Gear oil rear diff Daz00Excursion Excursion - King of SUVs 16 12-08-2011 09:30 PM
95 Explorer XLT-What gear lube to use? john111222 Oil & Lubrication 3 09-05-2004 06:17 AM
Rear end gear oil in 1999 E-150 phoneman Clutch, Transmission, Differential, Axle & Transfer Case 4 03-21-2004 06:53 AM
Tags
105, 2003, duty, f150, f250, gear, lube, oil, standard, sterling, super, suppose, take, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
