LED Light Bar - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
LED Light Bar
Old 05-05-2012, 12:11 PM
Thomas D.'s Avatar
Thomas D. Thomas D. is offline
Thomas D. is starting off with a positive reputation.
LED Light Bar
I'm looking at the 30" Vision X low profile LED Light Bar. Want to install it in the top of my 2011 SD grill. Catalog dimensions say it will fit. Just wondering who out there has already done this install on their "C Clamp" grill. Any pics or advice would be helpful. Thanks.
Old 05-06-2012, 11:39 AM
Thomas D.'s Avatar
Really. I can't possibly be the first one to consider this installation. Has anyone used the Vision X Light Bars at all. The online rep. says they can customize the bar to use 10 degree LED's in the center and 40 degree LED's outboard. Any suggestions. Guess they also have a Dimming option now too.
Old 05-06-2012, 12:59 PM
shaneinga shaneinga is offline
shaneinga is starting off with a positive reputation.
I have an led light bar that goes under my tail gate, between the bumper. Hooks into the trailer lights and lights when I brake, turn, etc. I don't think I have ever seen one where you are trying to put it.
LEDs are easy, what exactly is your question? If you like it, get it.
In my experience I would not spend more than 50 bucks on any of the aftermarket light bars, unless they come with a warranty. My first one I spent over a hundred on, the side where the wires come in completely shorted out.
My next one was 50 bucks off amazon, and I sealed it where the wires came in.
If this shorts out, it will be the last one I buy.
Old 05-06-2012, 01:05 PM
Old 05-06-2012, 01:51 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Wow. The last 2 posts are like the blind leading the blind! The visionX light bars are off road lights (forward illumination), they're ridiculously bright! They're not cheap china made accent lights. Not sure how the visionx lights mount, or if they'll fit in the 2011 grille, but it sounds like a fun project!
Old 05-06-2012, 02:02 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
I have seen a couple guys in the raptor forum go that route but no superdutys though. Excited to see it though.
Old 05-06-2012, 08:12 PM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
From the spec sheet on their website, it should work. Mount the light in the grill wherever you can being sure to leave aiming clearance. Check your local laws for height restrictions for on-road use.
I would run the wire in loom up,the hood along the driver's side and tie off on the truck loom over the upfitter/pass through bundle. I would use one of the heavier upfitter switches.
When you install this, take step by step pictures to share here.
Rigid has a low profile bar too. None are particularly friendly on the checkbook....
Old 05-06-2012, 09:43 PM
Gordon-0 Gordon-0 is offline
Gordon-0 is starting off with a positive reputation.
those vision x lights are ridiculously bright.
lets see what you come up with.
Old 05-06-2012, 10:04 PM
fireball318's Avatar
fireball318 fireball318 is offline
fireball318 is starting off with a positive reputation.
50 bucks x 14 = vision x light bar
Old 05-06-2012, 11:29 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Just asking the same questions in the 6.7 forum:
http://www.ford-trucks.com/forums/11...l#post11799973
my stepsons raptor has the rigid industries and they are BRIGHT !
on edit - sorry - wasn't looking for dress up - am more interested in light for night drives in the boonies
Old 05-07-2012, 10:57 AM
Thomas D.'s Avatar
Yes, off road use only (wink, wink). Actually, I plow and want some moose lights for my winter, night time trips to Anchorage. Couldn't find small enough profile lights on the Rigid site. The Vision X rep returned the information to me immediately. Was hoping I wasn't the first to do this. The Vision X mounting bracket only show a 15 degree adjustment from horizontal and I really wanted a rear mount on the back side of the grill. Appreciate the responses. This will be the first time I use the "Up Fitter Switches" also. Will be making the decision to order this week. Another bonus was Free Shipping to Alaska & Canada. That's something that is almost never seen. Pics provided upon installation. Will still take any suggestions out there.
Old 05-07-2012, 01:55 PM
majkthreads's Avatar
majkthreads majkthreads is offline
majkthreads is gaining momentum as a positive member of FTE.majkthreads is gaining momentum as a positive member of FTE.
This rigid light bar 20" SR-Series Hybrid LED Light bar
I slightly slimmer than the vision x.
I have a 20" combo from Rigid that I'm currently mounting on my 12 F250
I run a 6" rigid on my atv and have two more I'm adding to the other two atv's. I don't have any experience with vision x but I've heard good things about them.
Old 05-09-2012, 10:52 AM
Thomas D.'s Avatar
.Hhmmm....... Ok, now rethinking and looking at the LED's. For some reason I didn't find those the first time around. Thanks for the Link.
Old 05-09-2012, 12:25 PM
jdadamsjr's Avatar
The rigid are pricy, but they were designed for military use from what I've heard....
so overbuilt
Old 05-09-2012, 03:22 PM
TXtinct's Avatar
TXtinct TXtinct is offline
You'll shoot your eye out
TXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputation
I can get the 30" for right at 400.00 shipped if I have a group buy of 4 or more. Not rigid but still a really good really bright light. The 30" is the second one down.
LED Off Road Light Bar/Pods Mount dave3406 2015+ F150 1 11-06-2016 01:19 AM
Led light bar Larietpsd 1999 to 2016 Super Duty 5 03-03-2016 08:10 PM
Behind the grill Methodic Menace 1968-2013 Full Size Vans 0 02-27-2016 06:17 PM
grill leds GORDEN1234 2015+ F150 2 02-11-2015 08:19 AM
LED light bars anyone? 78F-250Lariat 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-05-2014 10:32 PM
Tags
2008, anchorage, bar, bright, bull, duty, f150, f250, f350, ford, front, headlamps, led, light, piaa, rigids, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
