1984 ford ranger engine
05-05-2012, 10:24 AM
on
my brother has an 84 ford ranger with a 2.8 v6 2wd with 312,000 miles on it, the motor is starting to wear out, it uses 2 quarts of oil every 150 miles, he found another ranger with a 4 cylinder and wants to put that in his ranger, will a 4 cylinder match up to the wireing or do we need to change anything?
05-06-2012, 04:28 PM
Is the 4 cyl a carbed engine, if so the wires can be worked out, I don't think the trans will interchange though, ports on the radiator will be different.
05-06-2012, 07:32 PM
on
its carburated, and were switching the radiator, motor mounts and transmission,
05-06-2012, 11:07 PM
Rebuild the 2.8 or find a good J-yard 2.8 to replace it with..........much less hassle.
YoGeorge
2021+ Bronco
01-18-2018 08:12 PM
tak lodar
1983 - 2012 Ranger & B-Series
07-26-2008 11:04 AM
Nightrain
33
01-18-2007 07:25 AM
asburydan
10-20-2001 10:33 PM
150,
1984,
28,
84,
codes,
cylinder,
engine,
engines,
ford,
orientation,
ranger,
specs,
swap,
v6,
www
