07 expedition with abs code c 1288
abs code c1288 comes up on this 2007 expedition
says brake pressure transducer fault
this has the roll stability control
and the sliding car icon is lit all the time as well
any ideas ?
where is this part located ?
anyone know the ford Part number ?
What vendors have this part?
any ideas ?
I looked in my 2007 Ford Workshop Manual. It says: If you install a new ABS module it must be 'configured' using 'the' scan tool. (it referring to the Ford scan too).
Code C 1288: Pressure Sensor Main? Primary Input Circuit Failure. This could mean the module has a problem.
From another article I read that the brake pressure transducer is located in the anti-lock brake system pump.
The Ford Workshop Manual offers lots of pinpoint tests using the diagnostic trouble codes from C1095 to C 1287. It does not list a pinpoint test for C 1288. Therefore I think there is no way to test the transducer while it is installed in the Hydraulic control Unit.
I am in over my head with this system and can't offer any intelligent thoughts on how to proceed.
Richard
Richard
Night Rod
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-29-2011 03:56 PM
