what 8.8 will work
Old 05-03-2012, 08:05 PM
f100today's Avatar
f100today
f100today is offline
what 8.8 will work
Ok, seems like I have seen that explorer 8.8 rear ends will work on our trucks? I would assume that when they are on the explorer they are over the leaf spring? So they would work over our leaf spring? Like an axle flip. What is the story?
Old 05-03-2012, 10:21 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Yeah, sit on top of the springs in the Exploder. Plus the Exploder has a weird angle on the leaf spring so you will need a major wedge or reweld the perches to get the driveline angle right. Not sure on the width, maybe a little narrow.
Old 05-03-2012, 10:25 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Why even consider an 8.8? I mean, ya can swap out the chunk for different gearing in about half an hour.
Try that with an integral carrier.
Old 05-04-2012, 01:15 AM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
I believe the face of rotor to face of rotor there 61.inches
Old 05-04-2012, 09:26 AM
aric1979's Avatar
aric1979
aric1979 is offline
I put a 1993 F150 8.8 in my 1979. Bolted right up no problems
Old 05-04-2012, 10:06 AM
HIO Silver's Avatar
HIO Silver
Full size Broncos and F-series up to 96. If ya need brackets, contact A&A Manufacturing.
Old 05-04-2012, 11:33 PM
willowbilly3
Because they are easy to find, cheap and a good rear end, you can get them with disc brakes. Plus if you need a limited slip they can be had for a lot cheaper than a 9". If you foresee a need to be swapping gear ratios, then yeah, stick with a 9"
I had a 3.73 8.8 with limited slip and discs that cost a buck fifty at the junk yard.
wdglide
21
12-04-2017 04:22 PM
scoutbuff
Bronco II
05-25-2015 03:00 PM
ETOWN55
35
01-24-2015 07:14 AM
chrono4
03-06-2005 11:31 PM
chrono4
01-31-2005 03:21 PM
Quick Reply: what 8.8 will work
