Flooding on start up
Rent/acquire/buy a fuel pressure gauge and hook it up. Have a friend cycle the key on-off a few times, it should go up to about 39-40 PSI and hold there. If the pressure starts to drop once the fuel pump turns off, then you could have a leaking injector.
Another possibility is a bad engine coolant temperature sensor.
As always, check the codes before buying any parts.
ProdigyMS
11-19-2013 02:57 PM
cheetah85
10-04-2008 03:18 PM
