1965 f100 altenator - Ford Truck Enthusiasts Forums
1965 f100 altenator
Old 05-04-2012, 09:10 PM
dcraig1000 dcraig1000 is offline
dcraig1000 is starting off with a positive reputation.
1965 f100 altenator
okay guys, this is driving me crazy. got a 1965 f100 with a 1985 302 in it. im trying to wire the altenator per the wiring diagrams that i have found for a 1964. it aint working that way. i have the 2 6 gauge wires(b/y and blk) one goes from the volt meter to the junction block,then from the junction block to the regulator and to thealtenator. the other, from the other side of the volt meter spliced in with the yellow wire from the ignition, to the other post on the junction block, then to the starter relay. problem is i have constant voltage at the regulator. i cant figure this crap out!!!!! help!!
Old 05-04-2012, 09:16 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I find what your doing hard also. I just put a one wire Delco alt on all my classics. It's simple and I need it simple.
Old 05-04-2012, 11:40 PM
tbm3fan's Avatar
tbm3fan tbm3fan is online now
tbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to behold
Might this help?
Old 05-05-2012, 07:24 AM
on the junction block, is that all alternator wiring? is the big b/y cable coming from the gauge? and is the blk cable coming from the regulator? also is that a yellow or white wire on the j block, and where is it going or coming from? on the starter relay, i know the one cable is coming from the battery, where are the other 2 coming from? sorry about all the questions, but i have tried alot of different ways with no success.
Old 05-05-2012, 01:50 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Not that knowledgeable when it comes to automotive electrical circuits. Apparently there a couple of variation to run the circuit but my 65 wiring manual was no help so the gauge did not get installed for several months. A FTE member emailed a diag., and for me the circuit finally made sense. One of my concerns was running high ampherage to the instrument cluster, so I decided to use a fuse block. Posting a pic of the diag. may be different than tmb3fam's. If decide to use the diag. strongly suggest doing the research and make sure you feel safe with the installation and that it meets the trucks application.
http://i300.photobucket.com/albums/n...os/Scan1-1.jpg
In my gallery I have a pic of the fuse block.
http://www.ford-trucks.com/user_gall...&albumid=43508
Old 05-05-2012, 11:59 PM
tbm3fan's Avatar
The two large wires, with the kind of beaten up brown insulation, on the junction box and bat side of solenoid are from the amp gauge. The black wire and yellow wire on the junction block are from the alternator (bat terminal) and regulator. The last one of the solenoid, black-yellow stripe is from the harness which runs along the back into the cab.
Old 05-06-2012, 01:54 AM
thanks guys. Ill let you know if everything works.
Old 08-04-2015, 11:38 PM
Christina Dillard Christina Dillard is offline
Christina Dillard is starting off with a positive reputation.
awesome
Quote:
Originally Posted by tbm3fan View Post
Might this help?
Yes what is that bolt on the fender well I need that for my truck and I can't find it plus no one else knows what the hell I'm taking about?
Sign
Christina Dillard,
65 Ford f100
Last edited by Christina Dillard; 08-04-2015 at 11:55 PM. Reason: Hey ,hey you! Not you too! Just kidding but I didn't get a reply
Old 08-05-2015, 03:53 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1961/64's have generators, 1965 and later have alternators.
Old 08-05-2015, 04:22 AM
tommyduncan tommyduncan is offline
tommyduncan is starting off with a positive reputation.
Quote:
Sign
Christina Dillard,
65 Ford f100
I think they were referring to that as a junction block. Whatever It is called I need one too...
Old 08-05-2015, 04:49 AM
Quote:
Originally Posted by tommyduncan View Post
I think they were referring to that as a junction block. I need one too.
D3TZ-14448-A (replaced C5TZ-14448-E & C7TZ-14448-C) .. Junction Block (Motorcraft DY-141) / Obsolete
1965/67 F100/350 except F350's with oil/amp gauges / 1965/69 C/CT500/1100 / 1967/77 F500/700 Open Drive-Away's (no cab) / 1970/77 C/CT600/900 with 60 & 65 Leece-Neville alternators.
NEWBURG FORD in Newburg OR has 1 = 800-683-1616.
SMITH AUTO CO. in Spanish Fork UT has 1 = 877-227-6484.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 71 = 800-476-9653.
Old 08-05-2015, 05:18 AM
Thanks again sir.
Old 08-17-2015, 07:13 PM
Fenderwall bolt
This is called a- POWER SUPPLY STUD, or Junction box. I found it at Tognotii`s 2509 Fulton Avenue for $13.45.
0401 code bobbydee 1997 - 2003 F150 0 10-21-2016 03:39 PM
64 F250 - 70 Amp Circuit Breaker and other stuff 1964FORDTUF 1961 - 1966 F-100 & Larger F-Series Trucks 5 10-09-2016 12:02 PM
1966 difference between f100 & f250 jamesvjordan 1961 - 1966 F-100 & Larger F-Series Trucks 9 12-28-2015 12:20 AM
65 F100 alternator wiring questions ridealong34 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-17-2015 02:34 AM
original amp gauge ??s 66ranger 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-02-2001 08:31 PM
Tags
1965, 1968, 390, black, constant, cougar, f350, ford, meter, schematic, solenoid, starter, syarter, terminals, volt, voltage, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
