Better performance all around? - Ford Truck Enthusiasts Forums
Old 05-04-2012, 09:02 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Hello i have a 351M for my 78 bronco and right now i have this
I was wondering if any better performance or anything would come out of putting this on there instead:
Also to add to that, would it hurt anything at all? It seems like it would suck in more air from being opened up but it is also sucking in a lot of hot air... I don't really know much about it so please, give me some air flow education
Old 05-07-2012, 06:24 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Its a good flowing filter. To verify it is of adequate size, here's a formula:
Minimum Air Filter
A= Filtering Area D= Estimated Height H= Height
For Off Road Use Multiply Height 1.5 to 2
A= (CID) (RPM) dividied by 25,500
H= A + .75 divided by (D) (3.14)
Old 05-07-2012, 08:40 PM
Quote:
Minimum Air Filter
So first let me tell you, I suck at math...
I think i did something wrong cause i got 109. I don't really know what that means. so i did it like:
(CID)= 351 (RPM)= I assumed you ment around the max RPMs which i think is around 5k so i went
351*5000/25,500 = 68.82 Then i went 68.82+.75/D being 2*3.14 = 109.22.
I don't know what that is supposed to mean and i am pretty darn sure i did that wrong.
Old 05-08-2012, 03:05 PM
No sweat...you were very close...
A= 68.82
Basically the air filter must be no less than 1.85" in height.
Old 05-08-2012, 08:41 PM
A= 68.82
Ohh ok i see. The reason i asked is cause a fellow FTEer has one of the aforementioned air cleaners and i might buy it from him if it isn't going to cost me an arm and a leg. So the height is that for clearance or the amount of air being taken in?
Old 05-08-2012, 09:28 PM
Thats for the minimum amount of air to go in for that size of engine and rpm. This formula is for round air cleaners/filters only.....there are different formulas for different shapes. Also, if you are actually going off roading with your truck, the other half of the formula is to multiply the minimum height by 2.....because of the extra airborne dirt you can expect a 50% reduction of flow through the filter as a result of the buildup, so by doubling, you have addressed that as well. In some cases, especially with trucks, in many HP applications & off-road too, we use to double stack the filters on top of each other to meet flow needs without having to replace the filter housing- just change the center stem!
Old 05-08-2012, 10:03 PM
Wow, that is a pretty sophisticated equation to get maximum air flow. Whats your opinion on the washable filters? I figured that would be the better/cheaper way to go so i can wash it out instead of replacing it. I don't do a ton of 4 wheeling around here but i plan to look around for some places when some issues are addressed.
Old 05-09-2012, 10:36 AM
IMHO I would look at a pre-filter...a piece of foam that goes aroround the outside of the filter- which can be easily installed befor going off road.
Old 05-09-2012, 05:20 PM
Oh i think i see what you mean, kind of an overlay filter.
Old 05-09-2012, 09:21 PM
you got it!!! any off road shop should have and they are very inexpensive!
Old 05-09-2012, 09:34 PM
Would it be easier/cheaper to make one? I don't know what their made of but i'm sure we got something in out house.
Old 05-10-2012, 10:34 AM
check out this link...........
Air & Fuel Delivery - SummitRacing.com
Old 05-10-2012, 04:18 PM
Thats pretty cool looking but dang $21 for a sleeve over the filter... Kinda pricey..
Old 05-10-2012, 05:44 PM
Yeah....but you can see how to make one......heck, you could even use a 4" wide cotton gause bandage and make one!
Old 05-10-2012, 07:06 PM
That would be weird to be prepping to go wheeling with a group and they see you wrapping your air cleaner with an ACE bandage haha.
TGM Reloaded! GruesomeJeans 1978 - 1996 Big Bronco 92 06-03-2016 01:06 PM
May BS Thread GruesomeJeans Washington Chapter 183 06-01-2013 12:42 PM
Another show, Another cool Bronco! GruesomeJeans 1978 - 1996 Big Bronco 8 04-04-2013 07:41 PM
So have any of you seen?.. GruesomeJeans 1978 - 1996 Big Bronco 32 01-23-2012 09:05 PM
TGM got some new shoes :D GruesomeJeans 1978 - 1996 Big Bronco 11 01-06-2012 11:43 PM
Tags
1979, 2014, 351, 351m, 66, 73, 78, back, bronco, ford, internatnal, performance, pistons, ranger, trucks, xlt, yard
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
