Boost Leak!
Old 05-04-2012, 06:55 PM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
Boost Leak!
I hooked up a boost gauge and had low boost. I then hooked up a cap to pressurize my intake system and found a leak coming from the passenger side boot on the lower intake Y pipe.
I'll probably end up taking the Y-pipe/manifold off to replace the boots, what else should I do while I'm in there? Anything that typically fails and is easier to access during the boot replacement is the type of input I'm looking for.
Thanks!
Old 05-04-2012, 09:29 PM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Hey John,once you replace those boots to a better quality boot you can rest at ease.If your uppipes are good you should be in great shape.
You still have the wicked wheel installed?
Old 05-04-2012, 10:29 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Get some Riffraff boots. You'll love them. I do.
Old 05-04-2012, 11:25 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
do Clay's Plemus Insert will you are there i love how they hold so i dont damage the pipe.
http://www.riffraffdiesel.com/catego...1-RDP-PRI.html
Old 05-05-2012, 07:38 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1 is offline
stinson 108-1
X-2 0n Clays plenum inserts. Get 4 t-bolt clamps from him also, they hold a lot better than the the ones that are on there now. Not much $ and easy to do.
Old 05-05-2012, 12:56 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
When I swapped my turbo I put the plenum inserts and I could tell right away I was glad the guys here talked me into buying them! I also got carried away and polished the inside of my intake while I had it out
brandon_oma#692
40
08-19-2017 10:03 PM
dmanshane
07-28-2012 12:44 PM
indyF-350psd
16
06-26-2012 08:21 AM
timmyboy76
04-19-2011 07:38 PM
marvinlong
13
06-24-2006 09:41 AM
Quick Reply: Boost Leak!
