engine gurus can you please help me with something?
https://www.ford-trucks.com/forums/1...a-beast-3.html
ok ther is the link to my truck its an 85 f150 with a 351 there has been alot of cunfusion as to weather or not i have a clevland or a windsor. frankly i dont care at this point which one i have. but i need to order some new gaskets for my headers and need to know for certian which engine i have.
also i am wanting to know more about my engine and i honestly dont know much about ford v8s i have mainly owned 300-6's up to this point.
what i know about it.. it has cheep headers and lan on replacing them in the next year. it also has an edlebrock performer intake manufold. and a holley carb. sorry i dont know what model carb it is,
what i want to know is how can i find out what heads i have and also is there a way to figure out what cam i may have? thanks for any info you can shed on the v8 noob
on
You have a 351 windsor, the cleveland was NEVER installed in trucks.. ever.
Heads are likely E5TE truck heads which are smog heads with monster combustion chambers so static CR is only about 8.3:1. Look for a capital letter cast into a top outside corner of one of the heads, The letter R will be for E5TE heads. If the truck was a factory 4bbl it has a pretty good cam and you stand to see substantial gains from headers and a free slowing exhaust, but if it was originally a 2bbl then the cam is pathetic and should be replaced with something like the Comp 35-234-3 cam and lifter set.
just ran my vin here is what i found
VIN 1FTEX15H0FKA29825
Vehicle History Report Get your Vehicle History Report NOW
Year 1985 Engine Type 5.8L V8 OHV 16V
Make Ford Driveline RWD
Model F-150 Ground Clearance No data in.
Trim Level SuperCab 2WD Front Brake Type No data
Manufactured In UNITED STATES Rear Brake Type No data
Body Style EXTENDED CAB PICKUP 2-DR Anti-Brake System No data
Transmission No data
Standard Seating No data
MPG Hwy No data miles/gallon Optional Seating No data
MPG City No data miles/gallon Tires No data
Dealer Invoice No data USD Wheelbase No data in.
MSRP No data USD Curb Weight No data lbs
just ran my vin here is what i found: VIN 1FTEX15H0FKA29825
(sigh) The 8th digit of the VIN is the engine code. There is no trans code within any VIN or any other of this wild mule ****.
Here is your VIN: 1FTEX15H0FKA29825 .. decoded correctly:
1FT = FoMoCo USA ~ Complete Vehicle.
E = Class E, 6,001-7,000 lbs. GVWR (Gross Vehicle Weight Rating range).
X15 = F150 2WD Super Cab Pickup.
H = 5.8L (351W) 4V
0 = Check digit, FoMoCo use only.
F = 1985.
K = Kansas City MO Assembly Plant.
A29825 = 1985 Numerical Sequence of Assembly, the trucks specific serial number.
Now, the VIN decode makes sense / Decoded from the: 1980/89 Ford Light Truck Parts Catalog ~ General Information Section.
351C = 1970/74 Passenger Cars/Ranchero's only, have 8 valve cover bolt holes per side (ditto 351M/400) / 351W's have 6 valve cover bolt holes per side (ditto 221/260/289/302).
And, 351C's (351M/400's) have no timing cover per se, just a flat engine cover plate. The fuel pump bolts to the left (drivers) side of the engine block, its bolt pattern is at 6 & 12 o'clock, the only pumps w/this bolt pattern.
IsaacJR75
01-30-2023 04:28 PM
reed1951
15
11-05-2010 12:14 PM
imlowr2
07-03-2008 11:55 PM
