OK Guys, solvethis one... - Ford Truck Enthusiasts Forums
Old 05-04-2012, 05:11 PM
oldtruck4u oldtruck4u is offline
oldtruck4u is starting off with a positive reputation.
Truck: 1998 Ford F150 Ex Cab. 5.4 ltr, auto, 2WD. 186,000 miles.
Problem: No guages.
History: Left center dash bulb burnt out so I pulled the cluster to replace bulb. Bulb replacement successful, now all bulbs are lit when headlights are activated. However, ALL gauges are out. They will not work at all. Checked ALL under dash fuses. All are good. Checked wires leading from shift stalk, all are good, no chafing, however, light at end of shift stalk for O/D OFF is not lit. GEM connection is clean and tight, truck has NEVER leaked at windshield seal. Disconnected battery to clear any codes and let sit overnight. Next morning truck started and ran normally however...No Guages.
Rechecked ALL fuses under dash, all are good.
Now, somebody please give me a clue, hint, or direction. I'm at wits end.
Old 05-04-2012, 07:30 PM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
Remove the cluster again and check the plugs. Has to be something you did.
Old 05-04-2012, 07:39 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Question. Does the charge light come on before cranking then go out?
If yes, that function is seperate from the rest of the dash.
Test/replace fuse 23 or the fuse feeding the dash or test for voltage past it.
This fuse feeds most all the dash gages, don't just look at it.
Good luck.
Old 05-05-2012, 12:01 PM
00GT
Quote:
Already checked each contact pin on all three plugs and checkec contact between contact pins and ribbon connection, all good.
Old 05-05-2012, 12:28 PM
Bluegrass
Good luck.
Have already checked all fuses, with particular attention to #2, #19, & #29. Will double check #23, thanks for the help.
I'll post the results
Old 05-08-2012, 03:19 PM
Solved!!
Although fuses tested good, fuse plug itself was cracked allowing fuse #29 to contact on one blade only. Since the one side of the fuse plug was tight, installing the fuse FELT like it was making contact. Had to pull ALL fuses and check each blade contact before I found the problem. Thanks to all for the help and suggestions!
Old 05-08-2012, 04:12 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Nothing like "coincidence".
Old 05-08-2012, 06:34 PM
Great job.
I pretty much knew what the problem was from experience and researching the wiring schematic and saw all the places and funtions that fuse fed and the way it acts when there is no power.
There should have been a string of codes from it.
The no proper forward drive but reverse was ok, was the thing that told me what was wrong.
Good luck.
Tags
ads, article, bluegrass, broadcasting, classified, dashboard, free, louisiana, oklahoma, online, powered, public, radio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
