New Guy
Parts
If you mean the window regulator, which is the guts that make the window go up and down and are inside the door itself, I have had no luck cruising scrap yards. I've never ordered anything from these people, but I have a 2009 catalog from truckandcarshop.com. I called them to get a 2012 catalog and they said they didn't have any at the moment, but that the only difference between a 2009 and 2012 catalogs are the price. Anyway, I have a 1948-1986 Ford Truck catalog from them and window regulators are $100 each, p/n 68-13612, '68-'72 F100-750. There's a left and right side and I would order them in pairs. The actual store is about an hour from me and I'll probably drive up there to see if it's legit on my first order. Hope that helps, Joe
http://classicfordtrucks.shutterfly.com/ Check here & call Riff. Tell him Steve from Indianapolis sent you.
Riff has done right by me.I had thought about relocating out to the area but he told me "No I need you there". When we get it going I will be handling his parts here in IN. I have only exchanged emails with Doug. He is in the Fridge section. That is his red & white '60 that is on the site. He uses the same pic for his avatar here. Tell him Steve & Susan from Indianapolis say hi.
The 1968/72 F100/750 (same: 1968/69 Passenger Car, 1968/77 Bronco, 1969/74 Econoline) window crank handle (C8AZ-6223342-A) did not come with a ****.
There were different colored ***** available to match the interior colors. No clear **** was offered for F100/750's until 1973, and this handle (D3TZ-1023342-A) is not the same style.
The **** included a stud that was placed between the handle and the ****, and the stick on cover (C8AZ-6223362-A also sold separately) used to hide the screw.
F100/750 **** color choices: 1968/69: Black, Blue, Ivy Gold, Parchment, White / 1970: Black, Blue, White, Red, Green / 1971/72: Black, Blue, Ginger, Green.
Carpenter's 1967/79 truck repro parts catalog lists the C8AZ window handle, and its cover, but only the black **** is available. It may be possible to find the other colored ***** NOS. Lemme know if interested.
btw: To install the **** on the handle. Place handle in vise, insert stud on inside of handle, **** on outside, than slowly close the jaws, pressing the ****/stud together.
It you use this method, but hit it with a hammer instead, the **** will shatter, then you'll need another.
86F150302
12-23-2007 08:09 PM
