You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Do any of you guys see any reason why I wouldn't be able to use the original tank on my truck as the WVO tank, and use a smaller (5 gal.) plastic one for my diesel start up?
You should be good to go then with the plastic tank.
The front tank on mine is plastic, but I don't drive long enough on my way to work, figured a smaller tank would heat faster, so I had to go that route.
Cool, now time to fab up some mounts for the startup tank. Well it stays hot enough down here in the summer for me not to worry to much about a heated tank for a few months.
Thanks for the replies
I know a few people running WVO in stock PSD tanks (plastic). Use a Hot Fox or similar heated fuel pick-up and no problems with the cold in your area. Ya don't ever want to heat 'the whole tank' anyway, its a waste of heat and shortens the life of the oil (expedites polymerization).
I also recommend TIH fuel lines and either a loop of TIH after fuel press regulator or a FPHE for heat. Shoot for at least 150* before the engine.
You aren't gonna share fuel pump or filter with diesel right?
__________________ 2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
