Short or charging problem? - Ford Truck Enthusiasts Forums
Old 05-04-2012, 08:56 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Hi all,
I've been noticing an odd symptom with my Bronco lately. The last few days while driving, I've noticed that the volt meter on the gauge has been abnormally high, like it's charging a lot. When I slow down, the needle drops to less of a charge (I'm just guessing because the engine's going slower).
Then, this morning I went out and my Bronco wouldn't start. Just the dreaded *click* *click* *click*
Radio and headlights came on fine. However, when I tested the battery, it was at around 9v.
Do I have a short somewhere draining my battery? Or is something in my charging system failing? Thoughts?
Old 05-04-2012, 09:54 AM
AzPete's Avatar
AzPete AzPete is offline
AzPete has a good reputation on FTE.AzPete has a good reputation on FTE.
Most likely a bad battery/regulator/alt....one of the three. Charge the battery and have the system tested at a local parts store...it is free.
Old 05-04-2012, 10:06 AM
Yeah, I had planned on doing that. It's just that all three are relatively new (battery is 2 1/2, alternator is about 3 or 4, regulator is about 2).
The fact that it was charging every morning is what seemed odd, like it'd been draining over night and was trying to fill back up. This time, it'd just drained too far to start.
But, if it's just a charging issue, hopefully it's an easy fix.
Old 05-04-2012, 10:20 AM
AzPete's Avatar
The high/over charging could indicate a bad regulator. The battery being dead could be because the overcharging has boiled the liquid out of the battery and the battery lost its ability to charge until filled again.
Also, the higher charging could indicate a bad battery, shorted or dead cell, and the battery is dead because of that. It would depend on how much the charge is over the normal 13.5 - 14 volt normal amount.
Of course, checking all your connections for being clean and tight is a must also.
Old 05-04-2012, 08:41 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Higher reading on the "charge" side of the ammeter means one of two things. The battery is not charging properly or the connection to the battery has weakened to the point that the voltage is not getting back to the battery. I know that sounds backwards but the way the ammeter works is based on resistance and a loss of draw on the charge circuit (without an increase in "drain") shows a higher charge.
The short answer, check and clean battery terminals and connections at the start solenoid, starter positive, and the main engine/frame negative before assuming some component has failed.
Old 05-04-2012, 10:32 PM
AzPete's Avatar
He is talking a volt meter.....
Old 05-08-2012, 12:35 PM
The alternator checked out alright so I swapped out the voltage regulator. The symptoms were the same before and after.
Turns out the battery decided to bite the bullet a few years early.
4 months shy of my 3 year warranty running out so I got a new one for free and all's well again.
99 f350 Clicking r1819m 1999 to 2016 Super Duty 5 12-09-2015 07:06 AM
charging issue after cluster swap. marshpoprock 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2012 10:05 PM
charging trailer batteries oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 19 04-19-2010 10:29 AM
Please Help Me Troubleshoot My Starting Problem... rutang Ranger & B-Series 2 01-07-2010 11:35 AM
Unusual Charging system problem 01FordCrew 1999 - 2003 7.3L Power Stroke Diesel 14 03-19-2008 05:26 AM
Tags
1966, 19731979, 1993, ammeter, charge, charging, classic, ford, gauge, high, lightning, mustang, problem, problems, shows, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
