'04 Explorer Won't Start
05-04-2012, 12:29 AM
on
My father in law has an '04 Explorer with the 4.0. He tells me he was coming home from an errand and it stopped dead, like the fuel shut off. I checked the inertia switch and it was ok. He replaced the fuel pump but that didnt fix it either. His description is as follows: when he turns the key, it will start, run about 2 seconds, if that, and shut off. It will not restart, if you want to call it that, unless it sits for a 1/2 hour or so. Then it's the same thing all over again.
Any help would be appreciated.
05-04-2012, 12:55 AM
No guessing, will it start and run on external test fuel???
Connect a fuel gauge and run a complete fuel pressure test.
Check the relays, FP CPU..... Philip
05-06-2012, 12:50 PM
on
It will not fire on ether...i have spark.
05-06-2012, 05:24 PM
Pull the Fuel relay, inject quick start into manifold via vacuum nipple and start....
If you are able to start this way, you have a fuel issue. The only way to diagnose that issue is with a fuel pressure gauge and completing all 5 tests.
..... Philip
shovel_1972
1978 - 1996 Big Bronco
04-06-2015 08:02 PM
SirArgus
02-09-2012 07:52 PM
jkarne
06-15-2010 06:50 AM
Race4Fun
25
09-29-2009 05:57 AM
jesterdog
01-30-2009 11:30 AM
04,
cycled,
dead,
explorer,
intermittent,
key,
powered,
sporttrac,
start,
truck,
vbulletin,
windows
