'04 Explorer Won't Start - Ford Truck Enthusiasts Forums
Old 05-04-2012, 01:29 AM
farmerwill farmerwill is offline
farmerwill is starting off with a positive reputation.
Question '04 Explorer Won't Start
My father in law has an '04 Explorer with the 4.0. He tells me he was coming home from an errand and it stopped dead, like the fuel shut off. I checked the inertia switch and it was ok. He replaced the fuel pump but that didnt fix it either. His description is as follows: when he turns the key, it will start, run about 2 seconds, if that, and shut off. It will not restart, if you want to call it that, unless it sits for a 1/2 hour or so. Then it's the same thing all over again.
Any help would be appreciated.
Old 05-04-2012, 01:55 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
No guessing, will it start and run on external test fuel???
Connect a fuel gauge and run a complete fuel pressure test.
Check the relays, FP CPU..... Philip
Old 05-06-2012, 01:50 PM
It will not fire on ether...i have spark.
Old 05-06-2012, 06:24 PM
aquanaut20's Avatar
Pull the Fuel relay, inject quick start into manifold via vacuum nipple and start....
If you are able to start this way, you have a fuel issue. The only way to diagnose that issue is with a fuel pressure gauge and completing all 5 tests.
..... Philip
2002 Explorer shuts off on it's ownThrott Eric3501 Explorer, Sport Trac, Mountaineer & Aviator 16 06-06-2016 12:15 PM
Troubles with my 04 6.0! Slingmud New Member Introductions 1 01-01-2015 09:47 PM
Start cold no start warm... bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 7 08-26-2014 06:41 PM
2000 4.0 Explorer, sometimes won't start. Khannink Explorer, Sport Trac, Mountaineer & Aviator 8 12-03-2013 09:04 PM
Intermittent Buzz and No crank.......Van won't start King of the Road 04 6.0L Power Stroke Diesel 27 01-29-2010 03:32 PM
Tags
04, cycled, dead, explorer, intermittent, key, powered, sporttrac, start, truck, vbulletin, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
