Loose steering
Loose steering
Hey everyone.
Didn't want to hijack Pastortom1's thread but reading it reminded me of something I've been meaning to ask.
The steering on my 85 F150 feels real loose. It doesn't wonder or anything like that, it drives good and straight it's just way to easy to turn if you know what I mean. I haven't got around to replacing the tie rod ends or bushings yet so kind of wonder if that might be part of it.
So, what can I do to tighten up the steering some? Do you think the tie rods and bushings are causing it? After reading Pastortom1's thread, do you think it might be the rag joint to?
Just one more thing on my growing To Do list.
Good point, actually thought about that. Like Chris said, I need to check it out for anything loose, then maybe try tightening the steering box a little. Always hated messing with them because over tightening is really not a good thing. Well guess, if I can get my dad out of the hospital long enough so I can work on the truck again, I need to move that up a few steps on my to do list.
I hope your dad does get out of the hospital soon.
When you get to testing the steering, have the person in the truck turn the wheel just enough to take the slack out of it - back and forth, back and forth. Then you start with the rag joint, watching the input shaft and the output shaft for the same movement. Then the sector box, which is where I think you'll find slack. And so on.
I replaced a sector box with a generic rebuild for ~$150 and it made a world of difference. But, that was after I played with the adjustment on the box and could only make it worse. YMMV, but I wouldn't expect too much from that.
Having said that, it doesn't cost anything, so it wouldn't hurt to try. However, make sure to mark where it was originally and only go in very small increments, like 1/8 turn or less.
One thing I did to try to isolate the "slope" was to jack one tire off the ground at a time. If you leave one on the ground that will tend to keep the whole steering in place and allow you to just check that side.
Jack one up and grab ahold of the tire and see if there is any play on just that side. If it moves, look up under at the tie rod and see if that's where the play is. If you don't see excessive play on that tie rod, check the other side. If both good then you know it's one of the other joints...or the box.
That's exactly where I have ended up with mine. Replaced all the linkage and joints and it runs very straight and no vibration...just a little loose in the box.
I was going to try to adjust the box but like others, don't seem to be able to get anywhere with it.
I put my brake on and block the wheels everytime now No matter what I'm doing!!
Thanks for the well wishes Gary, got him home today. Just have to keep and eye on him for the next few days, well more than normal that is. At 89 even the small things can be major if you know what I mean.
Thanks for the replies everyone. Hopefully I can start checking things out a little tomorrow. Really got me to thinking about the fact that probably all the steering components are about 28 years old. So probably not a real bad idea to think about replacing the tie rod ends and bushings, and maybe the steering box, anyway. Like I said earlier, it drives strait just feels loose. And it sounds like trying to adjust the box is kind of a wasted effort.
This kept the Re-alignment to a minimum.
Also, I was able to get all the components on Amazon for about $180....All MOOG
I didn't want to scare you away from adjusting the box, just from expecting it to be a miracle cure. It won't cost anything and might actually help a bit, so I would try it just to see. However, make sure you mark where it is so you can get it back there.
