Spark plug broke, removal, lisle tool - Ford Truck Enthusiasts Forums
Old 05-03-2012, 10:07 PM
JRS2's Avatar
JRS2 JRS2 is offline
JRS2 is starting off with a positive reputation.
Have been having fits with one plug on my 92 5.0 L motor. Broke off plug flush with head. Got porcelain and electrode out, been hitting it with Kroil off and on for about 2 weeks, tried a torch to heat head # 5 easy out and the lisle tool. Still no luck. With the lisle tool, is that generally used to pull the portion below the threads for the 5.4 L 3 valve engines ? I believe it is and since I needed the reverse thread, tried to use that on the inside of the plug surface. Well, I managed to simply have it thread all the way into the cylinder I believe, no luck breaking loose from the threads. I no longer see the spark plug tip, so either bent that straight or broke it off in the cylinder ....
How SOL am I now ?? I did read a couple other threads re: using the straight flute but this is the front cylinder and the exhaust manifold is right there on the 4 sided extractor only able to get an adjustable wrench on it, but not square - because of the depth .... Suggestions, short of removing head ??
Thks
Old 05-04-2012, 09:59 PM
JRS2's Avatar
Ok guys nevermind. Got my answer from a tech at Lisle. Since I could get to the shell of the plug with heat - he recommended go ahead and make it hot. I did and now a happy camper again, now going to replace all 8 plugs with antiseize and no over torque ....
Old 05-11-2012, 10:27 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Yep, I antisieze any plug I put in. Any new vehicle I work on I always remove them and gob them up. Someone will thank me somewhere down the line.
New member 5.4 spark plug thread question Canatct 2004 - 2008 F150 0 06-18-2016 09:11 PM
5.4 3v woes champlainl 1999 to 2016 Super Duty 12 05-10-2016 01:34 PM
Another spark plug story milliesdad 2004 - 2008 F150 4 04-01-2016 07:31 PM
5.4l triton spark plug removal Crf45or1991 1999 to 2016 Super Duty 4 10-06-2011 09:14 AM
spark plugs 05 - motor removal??? jwrboss302 Expedition & Navigator 5 10-25-2010 01:53 PM
Tags
60, bent, broke, broken, f150, fe, ford, lisle, plug, removal, remove, spark, tip, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
