steering column issue
i took my steering column apart to replace the upper column berring and the metal sleeve that sits directly on top of the berring has a split in it is that normal and it has sharp edge on it? and could that be causing the slop in my steering wheel and not the berring? if not how the heck do i get the berring out of the column?
As far as removing the bearing I used a small screw driver to work it out.
It took a few minutes but it came right out.
Looking at your signature, I'm not sure what truck you are talking about, I am assuming it's the 95.
Here is a link to when I replaced mine. https://www.ford-trucks.com/forums/1...ml#post9495375
Hope it helps
Try this link, navigate your way to the Steering Section (11).
1996 Bronco/F-Series Workshop Manual
Hope it helps
got all the parts today and now i cant get the part that holds the bearings back on like it is hitting something but i cant see what the tilt latches are out of the road as far as i can tell. i messed with it for about a hour with no luck-now what should i try? and when i took it off the little gear at the end of the key switch fell out how does it go back in?
I'm not really sure what parts your talking about, my experience is with the upper bearing only.
Go the Section 11 in the Bronco link I sent you eariler.
Scroll down to the bottom where the "Disassemble/Assembly section is and have a look there. It tells you how to replace the bearings.
I hope this helps, sorry I couldn't be more help.
project40
05-17-2007 11:20 AM
