86 302 f150 i need help with timing - Ford Truck Enthusiasts Forums
Old 05-03-2012, 03:13 PM
Anthony Light Anthony Light is offline
Anthony Light is starting off with a positive reputation.
i need help timing my 1986 f150 it has the 302 and i get the #1 piston to tdc and the rotter button to the #1 plug wire but the crank timing mark is about 180 out.. the truck will start and idle ok but as soon as it gets worm it wants to die. how do i get the crank make rite?
Old 05-03-2012, 03:50 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Welcome to FTE, Anothony.
You need to be TDC on the *compression* stroke, not the exhaust.
Old 05-03-2012, 04:00 PM
i have done it about 20 times and i know for sure that the last five times have been
Old 05-03-2012, 08:10 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I'm thinking you must be correct that it is on the compression stroke or the engine would never run. Given that, the harmonic balancer must have slipped, which isn't too unusual. Having said that, is it exactly 180 out? If so I can't believe that it has slipped exactly 180. But, a slipped balancer is all it can be.
You can either replace the balancer, which is what you should do, or mark the true TDC and then something like 10 BTDC using measurements. But, the balancer is highly likely to slip more, and can even come off the hub so you really should replace it.
87 302 Crank Twice to Start capnbass91 1968-2013 Full Size Vans 4 07-09-2016 05:56 AM
Slow turning starter BTFordGuy302 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 39 06-12-2016 06:20 PM
302 towers 79f1dy 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-20-2016 06:34 AM
302 timing FordF100man Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 10-15-2015 11:29 PM
94 F150 starting issues Will5o5 1987 - 1996 F150 & Larger F-Series Trucks 6 04-26-2014 04:14 PM
Tags
1986, 302, 86, 87, balancer, check, controls, f150, ford, ignition, jumped, marks, slip, time, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
