4x4 conversion for 62 f-100 longbed 2wd - Ford Truck Enthusiasts Forums
Old 05-03-2012, 07:46 AM
praisethelowered17 praisethelowered17 is offline
praisethelowered17 is starting off with a positive reputation.
hey, so i'm thinking about putting a 4wd conversion on my 62 f100, just curious as to what all that entails?
Old 05-03-2012, 09:08 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Unless you love you truck or it has some special family history, it would be a ton easier and cheaper to find a 4x4 truck. I'm not trying to talk you out of it, but I'm in the middle of updating a '66 2wd to a modern chassis 4x4. It's coming along, but it's a project I wish I didn't start. (and I've been fabricating for 20+ years)
Old 05-03-2012, 09:41 AM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
Don't know where you're at, but in a local salvage yard (ND), there is a mostly complete 62-63 Ford F100 4wd. As stated, would be easier to start with that. Wish I could save it, but have too many projects.
Old 05-03-2012, 10:00 AM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
I agree with the others, the frames on the 4x4 are different than the 2wd truck. It can be done; with a lot of work and fab. Find a early to mid 70's 4x4 with P/S and P/B for a donor and move your 62 body over to.
Old 05-03-2012, 10:31 AM
I'm located in Chicago, and just getting some ideas for the old truck
Old 05-03-2012, 11:48 AM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
Are we talking a 2wd integral to 4WD?
Old 05-03-2012, 11:55 AM
Sorry to seem ignorant but what is integral?
Old 05-03-2012, 12:22 PM
kjvforme's Avatar
integral was Fords name for the unibody.
Old 05-03-2012, 12:40 PM
Oh, then no, seperate bed and cab
Old 05-03-2012, 02:43 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Not familiar with the 61-64 chassis, seems if one was set on making the swap it would be slightly less complicated than if it were 65-66, with the I-beam front suspension,which I definately would not recommend!!, perhaps members more knowledgeable with 61-64 chassis can advise. I tend to go with taking body off and installing on the 4x4 chassis. Anyhow, had an urge to chime in.
Old 05-04-2012, 12:32 AM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Simple Swap.
1. Add front drive axle from any 59 to 65 F100 Or from a 59 to 77.5 F250. you can even add late model ford live axles if you relocate the leaf spring mounts. Steve at Industrial Chassis has 3" leaf mounts for 3" Axle tubes.
2. Find and mount a divorced case T Case from any 59 to 65 F100 or 59 to 77,5 F250
3 Add Propeller shaft from current trans to T case. Add Drive shafts from T case to Front axle and rear axle.
4. Place levers into cab to actuate the T case.
It is very simple, with minimal fab skills required.
Garbz
Old 05-04-2012, 09:35 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Yep, the 4x4's are not that different.....
Also make sure your front and rear axle ratios match. And you will need lift blocks on the rear axle to level it back out.......
Old 05-04-2012, 10:56 AM
Quote:
Originally Posted by garbz2 View Post
Simple Swap.
Garbz
That's a lot more simple than I would have thought! And that absolutely all you would need to do a full swap?
Old 05-04-2012, 03:49 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Simple Swap.
5. Add all the time (and money) it's gonna take to find all these parts. Don't forget the front springs/shackles and steering gearbox/Pitman arm, cuz 2WD ain't the same.
What conditions will all these used parts be in? I can just imagine...worn out. The springs will be sagging like an old nag, may have broken leaves. The shackles and bushings will be his-tor-e.
The gearbox will have 4-6 or maybe more inches of play. Will need everything replaced internally. The front driving axle and transfer case will need new bearings for sure, prolly more parts.
Drive/coupling shafts may be oughtta round, will need to be straightened. Will need new u-joints, hope the yokes are OK.
It may be a simple swap, but...you have the knowledge and skills that most peeps don't. So you'd be aware not to buy worn out used crap that's gonna take a pile of dough to fix.
bertha66: There is no such thing as an F100 4WD with P/S until 1973, then it's (1973/75) the awful Garrison Power Assist P/S, replacement parts are slim and none.
The manual gearbox box is used, as it has nothing to do with Power Assist.
And 1973/79 F100 8' Stylesides have a 133" wheelbase. What is the wheelbase for 'wrong bed' 1961/63 Stylesides? 122."
Old 05-04-2012, 06:01 PM
bertha66's Avatar
That's ok Bill about the P/S, I use a Toyota box anyway.
4WD conversion Jerry Husky 1967 - 1972 F-100 & Larger F-Series Trucks 6 08-31-2016 10:51 PM
1972 F100 Brake Conversion 2WD bdubs1127 1967 - 1972 F-100 & Larger F-Series Trucks 50 06-27-2015 08:22 PM
4wd conversion mxer0022 1967 - 1972 F-100 & Larger F-Series Trucks 53 04-25-2015 01:39 PM
Disc brake conversion jbvalusa19 1957 - 1960 F100 & Larger F-Series Trucks 1 01-28-2014 11:03 PM
62 Unibody CV swap crtrck48 1961 - 1963 F100 Unibody 1 07-31-2012 09:03 PM
Tags
100, 1962, 2wd, 4wd, 4x4, 77, base, build, conversion, f100, ford, lifted, ma, meets, swap, thread, truck, unibody, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
